Forum Moderators: RedPhantom
Hi basic, how about a mat pose, with the visibility dependant on the materials? The only way I could think of to do it. Don't think I've ever heard of a body part toggle visibility pose. convert your mc6 to a pz2 by changing mtlCollection to figure, saving, and changing extension to pz2.
Edit_ if there is a toggle body part pose, also interested to know.
In the .cr2 there's a value "on", which can be changed to "off", for each body part. It's the second entry in each body part listing, directly below the body part name. I guess you could write a pose to change this value but I haven't tried it meself. It certainly works if you edit the cr2 directly but beyond that I couldn't say what to do.
From Secrets of Figure Creation with Poser 5:
"Another item of note for the version section is a pz2 trick. If you set a pz2 file to version 3, you can use the code "on" and "off" for each body part to show/hide the part. In later versions, it is impossible to create a Pose file to turn parts invisible or visible."
Hide/Show pose files, example shoulder hide...
version
number 3.0
actor lShldr : 1
off
Use .pz2 extension, just tested on v4, poser 8, works.
If you own anything by Xurge, he usually provides pose files for turning off body parts to eliminate appearance of poke-thru. Other vendors also do it. But Xurge comes to mind immediately. Then you can just look at the pose file to see what he did and how it was formatted. :)
I'm trying to create a pose file that includes visibility settings. Can anyone tell me what code to manually enter into a pose to set the poised parts INVISIBLE?
