Forum Moderators: RedPhantom
Good work! but her right hand looks a little bit over twisted, and the way her left thigh looks in the connection to the body. (but this is something you could do with a little bit of post work). :) If I am correct, then the cloth is painted on the body texture. if I were you I would ad a shadow efect to the cloth lair. (maybe I am wrong, I am not that an expert.)
Thanks! The swimsuit is an actual conforming garment, part of the SMV Essentials II pack. I do fit them closer than most! Your right about the thigh, I got to work on the joint parameters a little more - I bring in SMV for trial fittings and run her through many of the Digiport poses like this, that is a good way to test 'em!
Attached Link: http://www.bbay.com
There is also a new SMV pose set at BBay by Digiport, I paid for this, I just wanted to say I'm a happy customer. I've used the the first two sets in zillions of renders I've posted here, I love 'em. Take a look if you've got the time. Set one is called th "Betty Paige" set, incidently. The poses should also work fine foe Supermodel Morph Vickie, too. Anyway, Set 3 has a lot couch poses, so you are going to need a sofa, I found this one at 3D Cafe, it is in 3DS, so you don't need Max. You will have to UV map it, though, if you want to put a texture on it, I just saved it as a OBJ and put a box map on it. In other SMV news, I'm going to try and combine all the various upgrades and updates in the base file that is sold, and add some extras, MAT poses, fix the hair to use the San Fran hair CR2 (as above, it does pose nicely, doesn't it - and this is a tough pose for hair). Don't let that keep you from buying her though, as before all upgrades will be available free, I only get your money one time!
