Fri, Nov 29, 4:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: How do I make GF2 cloths work on V4 in Poser Pro? is it possible?
rowlando ( ) posted Thu, 26 March 2015 at 5:28 PM · edited Fri, 29 November 2024 at 4:05 AM
I thought I might buy some of the G2F clothing. How do I make GF2 cloths work on V4 in Poser Pro? is it possible? Any links not daz ones please.
Thanks Rowlando
Seek what you can never loose
Vaskania ( ) posted Thu, 26 March 2015 at 5:37 PM
You'll need a copy of poser with the fitting room. I know it's in PP2014 as I have that, but not sure if it's in 10.
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
rowlando ( ) posted Thu, 26 March 2015 at 5:40 PM
Yes have it with Poser Pro 2014, so the fitting room will install DAZ files or is it importing them using DSON thing and then going to the fitting room
Vaskania ( ) posted Thu, 26 March 2015 at 5:53 PM
For the files you'll need the DSON Importer, the DSON core files of the product, as well as the PoserCF versions.
-----sig-----
rowlando ( ) posted Thu, 26 March 2015 at 6:32 PM
Yah sounds a lot of messing around, and then there is where all this stuff is stored, guess its a big learning curve if I think its worth it.
cheers
hborre ( ) posted Thu, 26 March 2015 at 8:48 PM
Unfortunately, if the Fitting Room doesn't give you the exact fit, you will need to rely on DAZStudio for the conversion.
WandW ( ) posted Thu, 26 March 2015 at 9:01 PM
If I were to try it, I would try exporting it as an .obj and loading that and bringing it into the Fitting Room...
rowlando ( ) posted Thu, 26 March 2015 at 9:13 PM
I think I would need to adapt to Daz studio first.
Thanks
WandW ( ) posted Thu, 26 March 2015 at 9:43 PM
You could load them in Poser with the DSON importer and then export the .obj...
PhilC ( ) posted Fri, 27 March 2015 at 1:48 AM
Wardrobe Wizard has been included in Poser since version 8. Use it to convert clothing from one figure to another. There is a whole chapter in the manual detailing how to do it. Basically select the figure the clothes were originally made for, select the figure that you want them to fit. Click the convert button. If required fine tune in the fitting room.
WandW ( ) posted Fri, 27 March 2015 at 5:57 AM
I'm pretty sure he's wanting to convert Genesis 2 clothing, Phil, not the SM/E-Frontier G2 clothing.  Or is there a WW plugin now for Genesis 2?
JVRenderer ( ) posted Sun, 19 April 2015 at 10:22 AM
,, test
Software: Daz Studio 4.15,  Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM,  RTX 3090 .
My Gallery  My Other Gallery
