Fri, Dec 20, 3:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Deactivation and the Download Manager :
pumeco ( ) posted Mon, 15 June 2015 at 1:26 PM · edited Fri, 20 December 2024 at 12:03 PM
I'm planning a reformat soon but I can't see anything about the deactivation thing for Poser 10, so I'm wondering if it's ok to just wipe it and it will work next time.  Can't remember where I read it, but there was a thread on here about some authorisation crap they decided to implement and I'm not entirely sure if it was just for Poser Pro or whether it includes Poser 10 as well.
Either way, does this mean that if I download Poser 10 on a new installation using the Download Manager, it will need to be activated?
If it does, I'll no doubt need to deactivate my current installation first somehow.
Also, does anyone have a link for the Download Manager itself so that I can use it next time?
vitachick ( ) posted Mon, 15 June 2015 at 2:57 PM
http://my.smithmicro.com/poser-pro-2014-updates.html
That's the addy I have...Just need your account update page..
Hope this helps
Win10  Poser 2014/Poser 11 Daz3D
hornet3d ( ) posted Mon, 15 June 2015 at 3:20 PM · edited Mon, 15 June 2015 at 3:21 PM
The Activation/Deactivation was introduced with the Game Dev version but there was some confusion recently when the SM web site stated that Game Dev and Poser 10/2014 needed and Internet connection for the 'Activation service'.  Since then Nerd 3D has confirmed the the Activation service is only applicable to Game Dev and the web site specs for Poser 10/2014 have been updated to reflect this.
As far as I remember the download manager will request your serial number but that is all and there should be no difficulty.
Chapter and verse can be seen at RDNA but as you are on Poser 10 there should be no need for concern.
Good Luck.
WandW ( ) posted Mon, 15 June 2015 at 4:05 PM · edited Mon, 15 June 2015 at 4:05 PM
Is there a time limit on how long Poser can be downloaded via the DLM?
I hadn't noticed there was one, myself, but I haven't redownloaded it in a while.   I keep the install files DLM downloads backed up on an external drive....
pumeco ( ) posted Tue, 16 June 2015 at 6:08 AM
Cheers Vita, Hornet, Rod, I appreciate it, though I should point out that Poser 10 has a different download location for Download Manager than Poser Pro.
Not sure whether the download itself is any different, but might be worth noting just in case.
vilters ( ) posted Tue, 16 June 2015 at 7:15 AM · edited Tue, 16 June 2015 at 7:16 AM
 What you can do :
Download Poser10 now. (If you did not keep the installation files)
That will be around 4GB in (from memory) 7 or 8 files??
Create a folder, "Poser10-Install" (you can choose the name)
Copy all the downloaded exe files in that folder.
And put it away on a USB stick, or external HD? whatever. (do not forget to add a small txt file with your serial number)
After the reformat, all you have to do is click the Poser installation exe file, and all files (the app and the content files) will install automatically in a single go.
And then install SR5.2 over that.
Done
pumeco ( ) posted Tue, 16 June 2015 at 10:56 AM
That's what I do as well, just shove each program in it's own folder along with a text file holding the serial :-D
Yup, might do that, depends if I can free-up enough space.
wheatpenny ( ) posted Tue, 16 June 2015 at 8:24 PM
Site Admin
I doubt if there's a time limit on redownloading Poser with the download manager. I bought PP2014 on the DVD, and I am still able to download it on the download manager using the serial number that came with the DVD.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
