Wed, Feb 26, 6:04 PM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 25 7:07 am)
Subject: Is there any Difference?
arrow1 ( ) posted Sat, 25 July 2015 at 7:52 PM · edited Mon, 17 February 2025 at 7:22 AM
Is there any difference between My DAZ 3d Library and My Library? I get confused with vendors product installations and free stuff in Zip files. Half the time I cannot find stuff that I have installed. Some say to install in My DAZ Library others say My Library. Another problem I have found is that some vendors use a runtime with geometries,textures and libraries etc. Where do these file go in DAZ Studio 4.8? I know where items go in Poser! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Razor42 ( ) posted Sat, 25 July 2015 at 7:59 PM
The issue comes from different versions of Daz gave different names to the folder above the runtime folder.
Really you can name this folder whatever you like as long as it is configured correctly within DS.
The variance you see in products ranges from preferred system of the vendor to the age of the product itself.
I tend to keep a DS runtime and a Poser runtime but the name will vary depending on what your first version was and what you have configured in both DIM and DS.
markht ( ) posted Sun, 26 July 2015 at 1:36 AM
The My DAZ 3d Library is located in public documents on a PC and is the default library used by DAZ Install Manager (DIM). I leave that library alone and let DIM manage that library. I install all content from other sources in My Library.
DAZ Studio supports both DAZ Format libraries and Poser Format libraries. The My Library and My DAZ 3d Library are folders that contain a DAZ Format library. Inside the folders for these libraries you will find a Runtime directory which is a Poser Format library.
If you get a vendor zip files with only a runtime with geometries,textures and libraries etc you can merge this into the Runtime folder under the My Library directory.
DAZ format products frequently also contain a Runtime folder, sometimes under the My Library or Content directory. This Runtime usually only contains Textures. Most DAZ Format products still store their texture files in the Poser Format Runtime library inside one of the DAZ Format folders.
bhoins ( ) posted Mon, 27 July 2015 at 9:10 AM
Specifically, My DAZ 3D Library is designed to have your content from DAZ 3D and My Library is for your content from you (or other sources) to avoid accidentally overwriting content you bought from DAZ 3D.
RHaseltine ( ) posted Mon, 27 July 2015 at 9:34 AM
Note, however, that the fourth generation base figures and ExP morph expansions do all have to use the same content directory - either all in My DAZ 3D Library or all in My Library (or all in any other directory you choose).
arrow1 ( ) posted Mon, 27 July 2015 at 5:24 PM
Many thanks everyone for the clarification. I downloaded Skinsofts free hair and put it in the "Hair" Folder as advised in the readme, but I cannot get it to work! Cheers
