Sun, Dec 1, 2:29 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Open GL ?
Sambucus ( ) posted Tue, 11 August 2015 at 12:43 PM · edited Sun, 01 December 2024 at 9:22 AM
 It seems my GTX670 is not compatible with open GL in Vue and Im having to use the software option. Am I losing much in performance? Studio 2014 is like treacle sometimes. Is there anything I can do to rectify the open GL problem. Ive got the latest drivers, have unticked background draw and use wireframe.
My other specs are;
Win7
Intel i73770
16gb ram
dreamcutter ( ) posted Fri, 14 August 2015 at 8:16 PM
No hardware openGL mode is compatible, or just the "shader 4 " will not work?  The only performance loss really is in the User Interface, renders will be very close to the same on a fast system.  I believe only anti-aliasing is the only render task that can be passed to teh GPU and it needs to be enabled, only in Vue 11 or later.
Sambucus ( ) posted Sat, 15 August 2015 at 12:23 AM
 Thanks dreamcutter. No, only the software mode is available but if you say Im not losing much Ill stop worrying about it. Renders aren't too slow, it`s the actual positioning of the objects that takes forever.
dreamcutter ( ) posted Sat, 15 August 2015 at 1:29 AM
Tnats expected however something isnt right.  That is a popular GPU and it should work fine. If you are using Windows default GeForce drivers try the Geforce/com factory drivers  - or the other way around.  You should see no conflicts or hardware errors in the Windows device manager.
