Thu, Dec 12, 9:01 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Dec 08 9:10 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Do a closet with cube
atpo ( ) posted Mon, 21 December 2015 at 6:25 PM · edited Wed, 11 December 2024 at 5:55 PM
I want to do closet with
cube ,but using knife
,which can not be
seperated face as two
doors that can be opened. Thanks.
LuxXeon ( ) posted Mon, 21 December 2015 at 6:28 PM
You need to screencap an example of the problem, please. I'm not sure I understand what you are trying to do.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
keppel ( ) posted Tue, 22 December 2015 at 1:38 AM
Try creating the closet exactly as you would in real life if you were working with wood. The cabinet is one object, each closet door are additional objects. Hinges, door knobs etc are again all separate objects.
My Renderosity Store
Virtual Furnishing
My Portfolio
atpo ( ) posted Wed, 23 December 2015 at 7:03 PM
thanks
atpo ( ) posted Wed, 23 December 2015 at 10:56 PM
Please look at pic. I use knife to cut face. But I want to let A and B
open,which just open two
pauljs75 ( ) posted Fri, 25 December 2015 at 6:44 AM
Split the edges around each door to separate them from the mesh, then make the doors separate objects.
Barbequed Pixels?
LuxXeon ( ) posted Fri, 25 December 2015 at 5:44 PM
pauljs75 posted at 5:38PM Fri, 25 December 2015 - #4245598
Agree with this. In edit mode, select the faces you want for your door, press the space bar, and search for "Edge Split". Select it from the list. Then press "P" on the keyboard to bring up the separate list, and choose "By Loose Parts". This will split the faces you chose from the base mesh, and make them separate objects.
My Free Models
My Video Tutorials
My CG Animations
atpo ( ) posted Fri, 25 December 2015 at 7:50 PM
Thanks a lot.
atpo ( ) posted Sat, 26 December 2015 at 7:05 PM
Thanks. It is done. But I find that Finishing
spliting and seperating
which all seperating parts
are the dependency
parts.And Need to
quit"edit model" to
"object model",then select
those parts and into "edit
model" and then select
edge and then "open
sesame". All the progress has more
steps. But click one door ,the
other is nondisplay.
While in maya,just need
creat cube then edit
mesh"split polygon
tool"then edit
mesh'detach component'
then'"open sesame".
Blender can also do the
