Thu, Feb 27, 2:58 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Copy morph dial settings from character to conforming clothes
phil_lawson ( ) posted Fri, 01 January 2016 at 6:19 AM ยท edited Thu, 27 February 2025 at 2:35 AM
Online Now!
Is there an easy way to copy the dial settings from a character to he conformed clothes? I'm OK on the guys in my scene, they don't have that many, but good old V4 has loads and its a long process copying them bit by bit to the clothing.
3DFineries ( ) posted Fri, 01 January 2016 at 6:49 AM
Dimension3d's Morphing Clothes is what I use to transfer morphs to clothing. It's pretty easy to use too.
Have a creative day!
My Lil' Store
hborre ( ) posted Fri, 01 January 2016 at 6:51 AM
Which Poser version do you have?
phil_lawson ( ) posted Fri, 01 January 2016 at 7:11 AM
Online Now!
Hi, I have Morcloth already and use it on a Windows machine to copy the morphs over to the clothes. What I can't do is to put the dials I have chosen in my character, e.g. Heavy at 0.3 and Bulk at 0.2, onto the clothing in one go. It's easy enough when only a couple of dials are used but if I've set 15-20 dials then its a real pain.
I'm using Poser 10 on a 64 bit Mac.
Thanks.
false1 ( ) posted Fri, 01 January 2016 at 7:53 AM
Once you've conformed the clothing to the figure choose the body of the clothing and go to the properties panel. You'll see 4 checkboxes. Click "include morphs when conforming" and "include scales when conforming". I generally click the other two boxes as well though I've not figured out exactly what they do.
Another method is under the script menu: Partners/Dimension 3D/Copy Values. This gives you options to copy various settings from the figure to the clothes. The advantage here is that you can then manually adjust the clothing morphs where as the checkboxes mentioned previously will override the dials and prevent you from fine tuning the fit.
________________________________
My DeviantArt Gallery
My Website
hborre ( ) posted Fri, 01 January 2016 at 8:10 AM
Select the donor figure, go to Edit>Copy, select the recipient clothing then paste. Values reset in one set of moves.
CrystalGames ( ) posted Fri, 01 January 2016 at 9:27 AM
The easiest way to do it is simply save your morphed figure as a CR2 with Use Binary Morphs checked in preferences. Remove all unused morphs from the figure. Once you have the PMD, you can INJECT just the morphs you are using into a single morph channel. Then, just copy THAT morph to the clothing.
