Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 8:38 am)
Easiest way would be to export them as one object, reload it and save it as a prop or you parent all props, except the master, to the master but if you move then an other part than the master the rest will not follow.
Ulli
Welding? If they don't have vertices at identical coordinates, No. Not within Poser. You need a modeler for that. You can File: export wavefront obj and select both props and export. If you import that it will be a single obj. How this obj is grouped depends on your export setting choices. If you just export those 2 objects with 'include existing groups' unchecked it will result in a single .obj read as a single group.
EldritchCellar posted at 5:06PM Wed, 20 January 2016 - #4250402
Ok, this one makes sense, and yes it's the dynamic hair I created. See, she looks bold with only one of them, and what I want to do is load 4 or 5, moving them slightly around to make her hair look full.
I'm gonna try that. Can you export the object after you edit them with magnets?
...wolfie
Yeah, as long as the resulting morphs are dialed in. They'll propagate as a default object state in the new object.
EldritchCellar posted at 5:14PM Wed, 20 January 2016 - #4250405
Thank friend! Ok, I just exported and imported, it worked... now when I imported at first, I had "percent of standard figure size" checked, with was 100%. It came out huge and on the ground... when I unchecked it, it was a little big and I had to make adjustmente (xyz scale & X scale).
Can you tell me exactly what I should have checked when doing both export and import? Also, how do you save as a smart prop? (I do know it has to be parented to the head)
...wolfie
For absolutely no changes to your object as it appears/positioned in the scene: export with all options unchecked (unless you want to consider groups, in that case 'include existing groups'). With all options unchecked no transformations will be applied during the process, what you see is what you get. Parent the prop, save to library, select yes: as smart prop.
Edit_Leave all options unchecked during import. You don't need any of that.
Simplest terms: export all options unchecked, import all options unchecked, save to library: yes, as smart prop.
Maybe something to be aware of when duplicating and merging obj with poser. Poser will create a new material, numbered for each merged instance. So if you have a box prop with a material named box mat, you create 2 more copies of this and export/import all three props merging into one prop the resulting prop will now have 3 materials: box mat:1, box mat:2, and box mat:3. To fix this append the .obj file with .txt, open in a text editor, search/find all three usemtl lines box mat and delete the :1, :2, :3 numberings after the name. Upon reimport you will again have a single merged material named box mat. You'll have stacked uvs also (if mapped), which can only be fixed in a modeler. Sometimes stacked uvs might be desireable... depending.
Good tip on the material zone, thanks! The export/import worked as you stated.
Funny thing is, I forgot, the original wasn't casting shadows nor showing up in render, and now the new obj isn't casting shadows either nor showing up in renders, I have every settings checked as it should... ??????? Strange, never had that happen. The hair I did yesterday casted shadows just fine, wonder what's going on here.
...wolfie
Visible in raytracing/ properties?
I'll confess, I've never played with posers dynamic hair (well maybe years ago)... I'm just assuming it has standard prop/.obj behaviors. Can't see why after export/import anything other than 'visible in raytracing or render' would be the culprit.
EldritchCellar posted at 6:14PM Wed, 20 January 2016 - #4250414
yep, all checked. Strange heh
Stumped.
Its showing in preview but not rendering? An object import? Are you looking at it in texture shaded mode?
Ok. Good luck with that.
Yeah, if you want. upload them to a Google drive or some such and sitemail me the link. I'll check them out later tonight and see what I come up with. She's a cute little thing btw. I think with a wee bit more body that hair prop will be rather nice.
Did I mention I don't use dynamic hair? Lol. There might be more to this than meets the eye... you might have to convert your hair in some way. Just something I'm seeing mentioned alot in relation to dynamic hair with a little research. Apparently dynamic hair is lines and not polys and requires a conversion. There's a free utility at sharecg...
http://www.sharecg.com/v/27296/browse/10/Software-and-Tools/Dynamic-hair-converter
Not sure if your merging and regrouping via export import has messed anything up though. (???).
Ok, I searched around wondering why it rendered yesterday & not today. The original hairs show up and cast shadows, and when I add them as prop, load the prop, they're still the original version (I see "recalculate" on them). It's when I export them that they don't work.
Later tonight or tomorrow I'll load both the originals (made two hairs) and you can have a play with them. Maybe you can find out why exporting them messes them up.
Right now here's the image of the hair I was playing with (this hair actually is two parts, top/sides and back)
...wolfie
They'll need to be converted via the utility I mentioned I imagine. Not much use in me trying to solve a problem for you with a windows only utility being that I use a mac. Well gotta go... hope you get that all sorted. Nice prop though.
Sorry I had to be out of town for a couple days, but I'm back. Got the utility, WORKS GREAT!! And thanks EldritchCellar! I guess that the dynamic hair is a known issue for exporting as obj.
So now, the utility made the hair fuller, so I don't need to multiply it as much. Gonna play around with the original (single) hair, load it a couple times and see what it looks like. For now, here's what it looks like with 4 of them (already exported together as obj) converted. And since you said the girl was cute, I thought I'd give you a little nice picture of her lol. Just bought Crazy Belle III and converted them to dynamic, love this set! And I love the fact that you can unclothify them to edit the morphs, very handy indeed!
...wolfie
Good job. Should have made her sneaking out of a window. Lol.
EldritchCellar posted at 10:00AM Sat, 23 January 2016 - #4250738
lol that's a good idea, gonna have to do that, only thing is, there's no such 3D houses around here that has the ability to open a window. Gonna see what I can do :)
...wolfie
Are there any way of welding 2 or more props and save them as 1? I have Poser9 (yes, still lol)
...wolfie
