Thu, Feb 27, 7:15 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 7:04 am)
Subject: FILE HELP
kumo ( ) posted Mon, 08 October 2001 at 11:07 AM ยท edited Thu, 27 February 2025 at 6:57 AM
is there a tut 4 what files go where in p4, coz i keep getting little grey shrugging men, cheers people KUMO
rodpanther ( ) posted Mon, 08 October 2001 at 11:17 AM
the lil grey man means you havent copied the rsr file to the same directory as the object/charcter file. Look for a file of the same name for example anything.cr2 goes in same dir as anything.rsr. Same file name differnt extention. Put both togther. God Bless rodpanther
kumo ( ) posted Mon, 08 October 2001 at 11:26 AM
CHEERS i'll give it a go, got files all over the place, and its drining me nuts
shadowcat ( ) posted Mon, 08 October 2001 at 12:23 PM
Actually there are 2 types of .rsr files, one is partnered with the .obj file in the geometries section, the other type is partnered with the library file (this is the one that will give you a thumbnail). here are the poser specific file types and where they go/what they are .cm2 = camera-subfolder .fc2 = face-subfolder .hr2 = hair-subfolder .hd2 = hand-subfolder .lt2 = light-subfolder .pz2 = pose-subfolder .pp2 = props-subfolder .cr2 = character-subfolder .pz3 = this is a "document" put anywhere and open with poser .obj = this can be either coupled with another file type and would need to be placed exactlly according to where the other files says (open other file with wordpad to check), or it is meant to be imported
shadowcat ( ) posted Mon, 08 October 2001 at 12:27 PM
oops forgot to mention that not all downloads will give you an .rsr file, they are not needed for the item to work. In this case you can make your own. Open the item, center in a way you like, then copy back into your library giving the item the same name as the "shrugging guy" it came from.
