What operating system are you using? And can you please tell us exactly what it says? If it is telling you you are out of memory but gives you a directory with an .obj name at the end, it's poser's way of saying it can't find the obj that it needs to load the kneepads. It may have been put into a curiouslabs subdirectory instead of metacreations. Find out where it wants the obj to be by writing down the subdirectory it gives you, then find the obj by doing a search and put it where poser expects it to be. Hope this helps, all users get bit by this sooner or later. 8^) Now if you are on a Mac that's a different story as I guess you have to allocate memory, don't know, don't own a Mac. Marque
Yes i dot have a MAC MY PC i a pentium 3 450mhz 64mb and Vodoo3 Graphics The first error says "Cannot open file Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj" Then it says "Cannot find Resource Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj" Then it says ! "you are out of memory" Please save your work and quit soon, you may also need to increase the amount of memory allocated in poser"
If you don't know where your object should be, Poser is telling you: Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj Find the Kneepads.obj and place it there. If there is no rbtwhizCharacters folder in your Geometries folder, you will have to make one, but be sure you use the exact names and spellings as Poser is giving them to you. You will also have to make the other folder inside that folder (SkateGear). It should work fine for you then :) Laurie
Right i have the Daz Knee pads, when i go to put them on Michael i get an error it says something like i dont have enough meory and have tolet ore memory into Poser. ANY HELP PLEASE.
