Sun, Dec 1, 4:29 AM CST
Subject: Uhm. Am I in over my head or can this be made posable?
TrekkieGrrrl ( ) posted Fri, 13 May 2016 at 1:07 PM · edited Sun, 01 December 2024 at 12:45 AM
Thing is, a Luxo lamp is held in place by springs. And I just don't know how to fake that in Poser. The rest of it is fairly simple to make into something that moves, but.. er.. those springs?!
CAN it be done or should I stop even considering how ;)
(oh and yes, I'm back. And modeling o/ )LuxoTG.jpg
FrankT ( ) posted Fri, 13 May 2016 at 1:35 PM
no idea but welcome back! It's been ages!
My Freebies
Buy stuff on RedBubble
adh3d ( ) posted Fri, 13 May 2016 at 1:57 PM
A "dirty" way , for the springs, would be make some morphs to expand them when you move the "other poser bones".
adh3d website
TrekkieGrrrl ( ) posted Fri, 13 May 2016 at 3:28 PM
Mm.. yes that might be the way. But ideally they should be slaved to the actual movements then, and although I think it's actually possible, it's a bit beyond my reach. Oh well. I'll have to see if I can fake it in some way then :)
And Hi FrankT :) Ages indeed. 3 years o.O BUT.. I'm clawing my way back now L
SamTherapy ( ) posted Fri, 13 May 2016 at 4:52 PM
WB, TG. I was thinking of making one of those a few days ago, and considering exactly the same as you. I reckon adh3d has it and that's what I also came up with.
quietrob ( ) posted Fri, 13 May 2016 at 8:49 PM
FrankT posted at 6:48PM Fri, 13 May 2016 - #4269033
Ditto that! You've been missed Trekkiegrrrl!
PhilC ( ) posted Sat, 14 May 2016 at 4:26 AM
You will need:-
  1. a morph to extend the spring.
  2. ERC control to link it to the required movement.
  3. the screw holding the end of the spring to be a separate bone.
  4. set the spring to "point at" the screw.
Also since you have parallelograms going on you will need to make the fourth arm of the parallelogram point back to the screw pivot at its base using a similar method.
TrekkieGrrrl ( ) posted Sat, 14 May 2016 at 10:11 AM
PhilC posted at 5:06PM Sat, 14 May 2016 - #4269118
You will need:-
Er.. right. On second thought, I think I'll just make the shade moveable L
I didn't even know I had parallelograms.. Here I thought I'd just made a desk lamp L ;)
But you confirmed what I feared. That it isn't just something (relatively) easy to make poseable. I might still give it a go, as an exercise, but.. I'm afraid I'll run out of steam if this takes too long. And I just don't want that to happen just when I made it back :)
At least all the bits are already seperated with different material zones, so it would be possible. Anyone wants a challenge? ;)
rokket ( ) posted Mon, 16 May 2016 at 8:33 AM
TrekkieGrrrl posted at 6:32AM Mon, 16 May 2016 - #4269140
You will need:-
Are you kidding me? I have to use donor rigs when I rig anything! But the model looks great, and it's nice to see you doing your thing again! Welcome back!
bhoins ( ) posted Mon, 16 May 2016 at 9:11 AM
ValueOPKey would be your friend for rigging the springs.
Key framing the spring movement and valueOpKey makes the spring move and deform correctly.
