Sun, Dec 1, 4:18 AM CST
Subject: Why is my character's fingers going inside of its hand??? HELP! I'm New!
authintix ( ) posted Mon, 30 May 2016 at 10:15 PM · edited Thu, 28 November 2024 at 4:45 PM
I've used the grasp dials later in the animation too
RorrKonn ( ) posted Tue, 31 May 2016 at 12:58 AM
some rigs have limits ,some don't. just don't bend stuff to far.
3DFineries ( ) posted Tue, 31 May 2016 at 4:51 AM
Try going to Figure>Use Inverse Kinematics & make sure there are no check marks. And if that doesn't work go to Figure> Use Limits & click it to add limits.
Have a creative day!
My Lil' Store
RedPhantom ( ) posted Tue, 31 May 2016 at 6:21 AM · edited Tue, 31 May 2016 at 6:21 AM
Site Admin
Your movement is set as splines and sometimes that causes the body part to move further than expected before moving back to where you want it to be. You need to change it to linear. In the animations pallet that you have open, 1 select the frames of the body parts that are causing you trouble and 2 click on the zigzag linear button. Your selection should change to match the color of the button.
seachnasaigh ( ) posted Tue, 31 May 2016 at 9:05 AM
I'll agree with RedPhantom - it's spline interpolation. You have a keyframe at frame 1, then a large gap, then two/three fairly closely spaced keys. That often produces wild motions in the middle of that keyless range. You might go to a frame in the middle of that keyless section (about frame 15?) and make a corrective pose adjustment to the hand; that may smooth out the spline for you.
authintix ( ) posted Tue, 31 May 2016 at 9:30 PM
Thanks you all!!!! I will try all these methods out right away!!
