Forum Moderators: RedPhantom
Apologies for not making a clickable link; I've honestly forgotten how to do it. :(
Hehe, use a Powerbrake, or YellowJacket replacement tubes, of course.
You could always retro mod the amp to cut the wattage, too. Not for the faint hearted but it's doable.
Here is the link to Sam's store
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
Sam the little chain link lookin doflingy in the bottom of the comment box. If you click that it will add the allocation for a link where you can put the description and the web link address.
PS Great looking Amp and guitar kit, Well done
- Johnny G
@ LPR001 - Thank you! Duh, I really should have known.
@ Jules53757 -
Thanks! Laurie - I'm not holding my breath. I like blue but not that much. :D
Not removable but you can make them invisible in the Hierarchy editor. You'll be left with the "feet" of the cab then. Same goes for the other cab.
The lower cab has recessed wheel cups modelled in, like the real thing, so the upper cab won't move about, even when you're cranked up. It's a very stable arrangement which I've used many times.
Here's a quick grab from Poser to show the cab with wheels removed in Hierarchy. I switched to Smooth Shaded view because it seems to look clearer when un-rendered.
This is really impressive work. How did you model the cables?
Thanks, people!
The cables were cylinders, which I extruded and used the "Sweep Region" function in Wings to give them a bit of sway and curl like real cables, rather than just hanging vertical. It was a matter of trial and error getting them to look right when they hit the ground but having my own rig right here was a big help, since I could take a look and compare. It was also good to be able to measure everything accurately, too. The calipers and tape measure were red hot, I tell you! :D
Hmmm.... nope. Page uses Plexis, AFAIK. Besides which, he's far (very) from being my favourite guitarist. That's Mick Ronson (also a Plexi user, or was) A close second is Adrian Belew. Last time I looked at his rig, it wasn't Marshall, though.
At long last, I'm back in business, or something. :)
More info here:
https://www.renderosity.com/mod/forumpro/?thread_id=2905672
