Thu, Feb 27, 2:15 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2025 Feb 25 8:23 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: Getting rid of ridges
arrowhead42 ( ) posted Thu, 23 February 2017 at 9:59 PM · edited Sat, 18 January 2025 at 12:48 AM
Hello - I do my modeling in Wings, and I have an issue I don't know how to handle. When creating something in Wings, if it has a smooth surface, it tends to have strange shadowy outlines on the face. (step1, in the attached diagram). I know this has something to do with the hardness or softness of the object face. So I highlight the offending areas, switch to my line tool and adjust the hardness to "Hard" (step 2 in the diagram) which gets rid of the shadowy forms, but leaves the model with visible ridges (result, in the diagram). My question is, how do I get rid of the shadows, without creating the ridges? Any help would be truly appreciated. Thanks,
Here's the link to my freebies:   https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
arrowhead42 ( ) posted Thu, 23 February 2017 at 10:00 PM
P.S. Ive noticed that the shadowy forms always appear around the edge of an object, or where I've "cut out" a section, as in a window or a door
adh3d ( ) posted Fri, 24 February 2017 at 10:53 AM
Hi, I try hard edges in wings3d to use in poser as you say, and it gives problems, what I use to do is not to use hard edges at all, you can try add a loop edge near of the cut edge in wings3d.
adh3d website
arrowhead42 ( ) posted Fri, 24 February 2017 at 1:50 PM
Ok, but what is a loop edge?
SamTherapy ( ) posted Fri, 24 February 2017 at 6:14 PM
Add a slight bevel to the edges and also, get rid of the ngons. There are quite a few I can see.
adh3d ( ) posted Fri, 24 February 2017 at 6:37 PM
Yes,as Sam said, or if you cannot change the joint between "poser parts" because the mode is already cut
I am using an old wings3d version, perhaps now it is an easier way, but you can follow this easy steps.
Note that if you slide the edge and the model is already uv mapped, you have to make some little changes in the uv map too to correct it.
adh3d website
adh3d ( ) posted Fri, 24 February 2017 at 6:46 PM · edited Fri, 24 February 2017 at 6:47 PM
Oh, I see now your picture now, I cannot see it before, if you are talking about the "hole" , in that case, the Sam suggestion is the right and only one.
adh3d website
