Sat, Nov 23, 12:34 PM CST
Subject: Comic & Painterly sketch styles
Death_Z ( ) posted Thu, 17 December 2015 at 6:26 PM · edited Fri, 22 November 2024 at 7:52 PM
Has anyone played with the new comics and painterly sketch styles. Curious how they are on the new system. What all styles does it offer now?
Boni ( ) posted Thu, 17 December 2015 at 6:32 PM
Boni
quietrob ( ) posted Thu, 17 December 2015 at 9:15 PM
Are these from the preview window or are full blown renders!!
Isn't Marina wonderful?
Boni ( ) posted Thu, 17 December 2015 at 9:38 PM
These are preview renders with the newer controls in PP11 & yes, I love Marina.
Boni
quietrob ( ) posted Fri, 18 December 2015 at 7:10 AM
Has there been any improvement to the sketch modes? Can Poser 11 produce full-on comic renders? I saw something in the advertising that showed it the new features to be as good as say, PWSketch, which I think is very good.
Sorry to ask all these questions but as a comic producer, I'm more interested in those features than anything else right now.
bantha ( ) posted Fri, 18 December 2015 at 10:49 AM
This is a Superfly toon shader, alone and with the lines (needs to be combined in Photoshop or so,)
-"Amazing Grace" Hopper
quietrob ( ) posted Fri, 18 December 2015 at 11:28 PM
That is very cool. The colors are pretty clean but flat. They can be blended together. The best part is that the characters seem more 2D than 3D! Thanks for the peek!
HartyBart ( ) posted Sat, 19 December 2015 at 4:30 PM
HartyBart ( ) posted Sat, 19 December 2015 at 4:36 PM
bantha ( ) posted Mon, 21 December 2015 at 3:31 PM · edited Mon, 21 December 2015 at 3:37 PM
This is a comparison between the NPR shader from the Mariko Project (which I used in my previous image) and a Shader published by Infinity10 on RDNA, he calls it a modified Sanne shader. Please take note, both shaders are very light dependent, the shader on the right can look more flat if a different light set is used.
But for a flat shader which even generates it's own lines, the second shader looks really good to me.
bagginsbill ( ) posted Mon, 21 December 2015 at 4:16 PM · edited Mon, 21 December 2015 at 4:17 PM
Can I ask, why SuperFly is generating interest in toons? FireFly is better at non-photoreal rendering and capable of more effects than SuperFly, because SuperFly's BRDF set is mostly devoted realism, whereas in FireFly I can make a much broader set of shaders.
In FireFly you can make things you cannot do in SuperFly. For example, the colors reverse in shadows like this: (image by Vestmann)
Sin City style image
See more about FireFly toon shading in this thread:
Cartoon Rendering And VSS
bantha ( ) posted Mon, 21 December 2015 at 5:06 PM
I know that, and I know how to get NPR images out of FireFly for quite a long while. It's just toying around.
The image above is rendered in FireFly.
HartyBart ( ) posted Sun, 24 January 2016 at 4:49 PM
estherau ( ) posted Sun, 24 January 2016 at 7:00 PM
that aiko one looks very nice HartyBart!!!
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Sun, 24 January 2016 at 7:01 PM
can you do one in a scene with some shadows?
DragonWhy ( ) posted Mon, 25 January 2016 at 6:38 PM
Happy to find some example of the comic rendering :)
I was just wondering if this feature is the same in Poser 11 as it is in Poser 11 Pro version ?
I was only really interested in the comic rendering so didn't want to blow a lot of money on Pro if I don't need to.
Also does it render quicker than a photo-realistic render ?
Many thanks !
estherau ( ) posted Mon, 25 January 2016 at 6:47 PM
Yes, it renders quicker.
DragonWhy ( ) posted Tue, 26 January 2016 at 9:35 AM
Can anyone comment on the other question ?
bantha ( ) posted Tue, 26 January 2016 at 12:55 PM
I do have Pro, so I cannot check but looking at the comparison matrix you should be able to work with the non-Pro version.
shante ( ) posted Wed, 17 February 2016 at 1:38 PM
Boni posted at 1:35PM Wed, 17 February 2016 - #4244777
funny. i used to create this imaging technique back in my photography days using 35mm film sandwiched with 35 mm slides or by projection onto 8 x 10 lith film in color darkroom. it was fun and expensive! good to see it is possible in poser. wish i could figure out how to do the same in photoshop for my older photos.
Boni ( ) posted Thu, 18 February 2016 at 6:47 AM
There are some actions sold here that can come pretty close in Photoshop ... I'm a little rushed right now, but I can look it up later if you want.
Boni
shante ( ) posted Thu, 18 February 2016 at 12:33 PM
thanks dear that would be cool.
Boni ( ) posted Thu, 18 February 2016 at 4:45 PM · edited Mon, 27 February 2023 at 4:04 PM
Here you go:
Tru Ink
Professional Comic Actions
I hope these help. Let us know and share ... we'd like to know how this works for you.
Boni
HartyBart ( ) posted Sat, 29 April 2017 at 8:16 AM
DragonWhy asked: is "this feature the same in Poser 11 as it is in Poser 11 Pro version?"
Yes, Poser 11 Standard and Poser 11 Pro both have the Comic Book mode.
HartyBart ( ) posted Sat, 29 April 2017 at 8:22 AM · edited Sat, 29 April 2017 at 8:33 AM
If you also render out a sketch layer of a suitable type (you may need to experiment for a while, on that) and the same size as your toon render, then in Photoshop you can use a big soft eraser to remove most of that sketch layer, just leaving shading that looks sort-of like hatching (see picture, below). Of course you have to run an Action to knock out all the white first, leaving just the sketch lines laid over your toon lines and colour flats layers.
Boni ( ) posted Sat, 29 April 2017 at 9:01 AM
Good to see renewed interest in this thread!
Boni
estherau ( ) posted Mon, 08 May 2017 at 7:07 PM
That looks great!
