Thu, Feb 27, 4:28 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Joint Controled Morphs that add up don't work
pitklad ( ) posted Sat, 10 June 2017 at 3:22 PM · edited Thu, 27 February 2025 at 4:19 AM
I have made a set of morphs that correct the front bend of the thigh
used the Poser Pro 2014 Goz plugin for Zbrush
But I want the figure to work on Poser 6 so afterwards moved there
I positioned the new morphs to the end of the list with Cr2editor so poser reads them first and their corrections makes effect
The morphs are made to add up one to the prevous
So 20 ranges from 0 to 1 for bend from 0 to -20
40 add up from 0 to 1 for bend -20 to -40 while 20 remains at 1
and so on until -120 with the step of 20
I connected the morphs to the bend dial with their limits 0-1 using the excellent python script ERC builder by ockham
The problem is although when set by hand they work fine (image below) when controlled by the bend they destroy each other
looking at the morphs on Cr2editor all the morphs get a deltaAddDelta -0.050000 so I am afraid this is the problem
poser can not recognise that they have different start
So I am asking if there is another way to make the morphs add up, maybe give more limits on the jcm not just the deltaAddDelta ratio
My FreeStuff
pitklad ( ) posted Sun, 11 June 2017 at 9:47 AM
YES! I found the answer in a tutorial I had already on my disc!
I'm so happy
To solve the problem a delay - empty morph is needed before the actual morph
The Tutorial is zipped and it is named HowToWriteERCcode.zip but it doesn't mention the creator
please if anyone is familiar with this tutorial let me know
I want to say a public thank you, the tutorial is wrote excellently, and also share the link for future reference
My FreeStuff
Allstereo ( ) posted Fri, 16 June 2017 at 3:42 PM
Hello Pitklad,
The tutorial was written by VK, a famous guru of the Poser community. The tutorial is no more available on the net (It was retired last year to my knowledge). For my tutorials on Poser dependent parameters (See the link below to my freestuff page), I studied extensively this tutorial as well as treads involving discussion and comments by VK. With the new Poser dependent parameter includes in Poser 8 and subsequent versions of Poser, it is more easy to program Joint Controlled Morph (JCM) relative to the old and complex method using only the "ValueOpDeltaAdd" operator. You can read my tutorials to learn more about Poser Dependent Parameters (Part 4 has informations related to your work).
Good luck in your project
Allstereo
Allstereo Freestuff page
pitklad ( ) posted Tue, 20 June 2017 at 7:11 PM · edited Tue, 20 June 2017 at 7:11 PM
Thank you so much for the information, it is a pity this isn't available anymore.
It is really good tutorial with great effort to explain really difficult technical poser stuff!
I have already took a look on your homepage so another thank you for your effort also!
My FreeStuff
