Thu, Feb 27, 3:45 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Removing shadow cams
gmm2 ( ) posted Mon, 02 April 2018 at 12:01 PM ยท edited Mon, 24 February 2025 at 6:55 PM
I'm working on a pretty extensive light set, so I'm stripping out all the shadow cameras to make a lighter file and not make a scene so cluttered. But I've run into a small bump.
Obviously, if I'm removing the cameras, "depthCamera" can't have an associated camera, right? So what do I put there? Is it something like "NOCAM"? Is it necessary to replace the camera name there at all?
SamTherapy ( ) posted Mon, 02 April 2018 at 6:13 PM
I have no idea but have you tried removing the line entirely? Save the set first then save the amended one under a different name and see if it works as it should.
gmm2 ( ) posted Tue, 03 April 2018 at 12:09 AM
I tried simply taking out a few cameras and seeing what happened, and there doesn't seem to be any problems leaving the depthCamera lines as-is. I was worried doing that might cause some sort of error, but apparently not, so... great!
