Thu, Feb 27, 2:51 AM CST
Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 23 8:32 pm)
banner
Subject: Random Problem Installing ZIP Files Into Poser 11.1 Pro
Nod ( ) posted Fri, 08 June 2018 at 7:57 PM · edited Thu, 27 February 2025 at 2:36 AM
I've been having a weird problem with Poser 11.1 Pro. When installing a file, the item in question isn't showing up in the Poser directory. This applies to installing the ZIP via the built in extractor, or doing it the old fashioned way and installing straight to the Runtime folder from the ZIP itself. If I use explorer, I can see the files happily sitting there in the appropriate folders, so it's not like they're in the wrong directory. It's just that Poser can't see them, not even with a search.
The weird part is that if I install them into Poser 9 using the exact same method, they'll show up in the Poser 9 Runtime which I have set up in Poser 11.
I've installed 100s of Zips and this has only happened with Poser 11. Any ideas?
donnena ( ) posted Fri, 08 June 2018 at 8:20 PM
IF you have Poser 11 open at the time you install the new files May or may not show up when you force a refresh on that folder.... Otherwise, I'm clueless.
Andy!
Boni ( ) posted Fri, 08 June 2018 at 9:00 PM
At the bottom right corner of your library window you will see a circular arrow. Whenever you install a new item zip or otherwise you need to hit that symbol. It will refresh the whole library.
Boni
Nod ( ) posted Sun, 10 June 2018 at 5:18 PM
As I've said before, I've installed 100s of Zips into Poser 11. I always do it the same way, it's just that sometimes the files can't be seen no matter how many times it's refreshed. It's like a random bug.
Miss B ( ) posted Sun, 10 June 2018 at 11:45 PM · edited Sun, 10 June 2018 at 11:45 PM
I didn't upgrade to 11.1, and this sounds like one more reason why I never will.
_______________
Butterfly Dezignz
Boni ( ) posted Mon, 11 June 2018 at 6:57 AM
For myself anyway ... I've found that when it doesn't show up it's because the zip file isn't nested properly ... and is in a "content" folder as per DAZ structure. I have to go in and move the runtime to the proper place. And I have PP11.1 with no issues.
Boni
hborre ( ) posted Mon, 11 June 2018 at 11:03 AM
It doesn't necessarily apply to just 'content' folder. There are individuals who nest a runtime folder within a description title folder that can throw the whole hierarchy into disarray. That requires manually inspecting compressed files for protocol integrity before installation. Where DAZ3D content is concerned, I use their Install Manager to install content to wherever runtime I want. The application systematically installs the files found within a Content folder, subsequently ignoring the Content folder altogether. Then again, DAZ based content files need to be nested within a Content folder, otherwise no installation.
Miss B ( ) posted Mon, 11 June 2018 at 11:48 AM
This is exactly why I manually install . . . folder by folder. Most folks I know think it's a big waste of time, but I never have a problem finding anything, because it's all where I want/need it to be.
_______________
Butterfly Dezignz
Boni ( ) posted Mon, 11 June 2018 at 4:05 PM
I always check the hierarchy of the zip when I download ... adjust it if necessary ... then I can install anyway I want. That is just my workflow. I find it easier.
Boni
ypvs ( ) posted Sat, 16 June 2018 at 5:24 PM · edited Sat, 16 June 2018 at 5:25 PM
I've used 7-Zip for quite some time but I assume WinZip etc work the same. You can actually open the folder structure in 7-zip to get to the runtime folder. When you extract it only extracts the path from that point down. It also keeps a list of recent destination folders so you can quickly jump to selected external runtimes
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
