Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 23 8:32 pm)
I didn't upgrade to 11.1, and this sounds like one more reason why I never will.
_______________
It doesn't necessarily apply to just 'content' folder. There are individuals who nest a runtime folder within a description title folder that can throw the whole hierarchy into disarray. That requires manually inspecting compressed files for protocol integrity before installation. Where DAZ3D content is concerned, I use their Install Manager to install content to wherever runtime I want. The application systematically installs the files found within a Content folder, subsequently ignoring the Content folder altogether. Then again, DAZ based content files need to be nested within a Content folder, otherwise no installation.
This is exactly why I manually install . . . folder by folder. Most folks I know think it's a big waste of time, but I never have a problem finding anything, because it's all where I want/need it to be.
_______________
I've used 7-Zip for quite some time but I assume WinZip etc work the same. You can actually open the folder structure in 7-zip to get to the runtime folder. When you extract it only extracts the path from that point down. It also keeps a list of recent destination folders so you can quickly jump to selected external runtimes
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
I've been having a weird problem with Poser 11.1 Pro. When installing a file, the item in question isn't showing up in the Poser directory. This applies to installing the ZIP via the built in extractor, or doing it the old fashioned way and installing straight to the Runtime folder from the ZIP itself. If I use explorer, I can see the files happily sitting there in the appropriate folders, so it's not like they're in the wrong directory. It's just that Poser can't see them, not even with a search.
The weird part is that if I install them into Poser 9 using the exact same method, they'll show up in the Poser 9 Runtime which I have set up in Poser 11.
I've installed 100s of Zips and this has only happened with Poser 11. Any ideas?
