Sat, Nov 23, 1:51 PM CST
Subject: How do I create a magnifying glass effect?
MDibble ( ) posted Tue, 02 October 2018 at 8:12 AM · edited Sat, 23 November 2024 at 1:38 PM
I've been trying to create a magnifying glass effect, but all I'm getting is black glass or, if I turn on transparency, very nice, un-magnifying glass.
Any suggestions or settings I should try?
I'm using a high rez ball with z-scale set to 15%.
Thanks!
Boni ( ) posted Tue, 02 October 2018 at 8:16 AM
A lot depends on the version of Poser you have. Theoretically you should be able to get close with the caustics of Superfly in Poser 11. But I don't believe it's possible with earlier versions of Poser.
Boni
MDibble ( ) posted Tue, 02 October 2018 at 8:42 AM
Well, fudge. I'm using Poser Pro 2014.
Thanks.
Boni ( ) posted Tue, 02 October 2018 at 9:56 AM
Don't give up ... there may still be a way. I know some pretty gifted Poser gurus around here. Let me do some research for you.
Boni
Boni ( ) posted Tue, 02 October 2018 at 10:24 AM
Bingo!! Here is your settings ... see if this works!!
From another thread here. 😄
Boni
raven ( ) posted Tue, 02 October 2018 at 10:33 AM
That's complex! :)
I just set a scene up in Poser Pro 2014, a square prop with a tiled texture, a stick man and a hi-res ball prop scaled to 25% on the y-scale to approximate a magnifying glass shape.
In the material room, I selected the ball prop and just clicked the 'add refraction' wacro.
This is the render from the front camera showing the magnifying effect.
MDibble ( ) posted Tue, 02 October 2018 at 11:42 AM
Thanks so much. I'll try it as soon as i get home.
Kalypso ( ) posted Tue, 02 October 2018 at 11:47 PM
Site Admin Online Now!
[Boni> From another thread here. 😄
Boni, could you please link the thread with this shader? Thanks!
MDibble ( ) posted Wed, 03 October 2018 at 7:41 AM
Well, raven's suggestion worked. My issue apparently was the magnifying glass prop I'm using has no curvature, so I thought the issue was the wacro. But the squished ball plus the wacro had the magnifying effect.
Thanks for your help!
raven ( ) posted Wed, 03 October 2018 at 7:55 AM
Glad you got it sorted! 😃
