Thu, Feb 27, 2:26 AM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 25 7:07 am)
Subject: What is Happening Here?!
Crispycraft ( ) posted Sun, 15 September 2019 at 10:12 AM · edited Thu, 27 February 2025 at 2:20 AM
I have loaded the Rainbow Light Bodystockings(G8F), and while working in either Texture Shaded mode or NVIDIA iray mode, there is no poke through, but when I render the scene, I get poke-through. Of course I have adjusted the stockings, and although that does eliminate the poke-through, it also looses the fit to the legs, which looks bad. I'll also add that the leg is not bent to any extremes, and there are no exaggerated body morphs being added to the G8F figure.
RHaseltine ( ) posted Sun, 15 September 2019 at 1:45 PM
Is there any displacement active on the hosiery or the figure?
Crispycraft ( ) posted Sun, 15 September 2019 at 2:25 PM
It does show that there are multiple displacement maps for my figure, but not for the stockings. How does this affect the rendering?
RHaseltine ( ) posted Mon, 16 September 2019 at 9:31 AM
As I recall the default Iray preview does not show displacement, so if it is moving the skin out that will not show until the final render. You could use a weight-mapped dForm or Push Modifier to make targeted fixes to the affected areas, or you could try removing the displacement and seeing if the result is acceptable.
wscottart ( ) posted Wed, 25 September 2019 at 6:36 PM
I've run across similar problems at times, next time I will know to check out those displacement maps. Thanks guys.
