Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2024 Sep 28 7:17 am)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Just had another one trying to create a thread in the Marketplace Support Forum, a few minutes ago, and from this computer
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
(N.B. I made the previous post purely to get a timestamp - the "failure to create a thread" happened a few minutes before that and from the same computer, so that may help you identify the log entry.
I did not have an image in the post, so the thought that it might be to do with images is incorrect.
However, when I eventually managed to create the thread (having retyped everything) the title was truncated (I think I'd used double quotes " around part of the title,and when the thread was created the first " and everything after it had vanished). So the problem might have something to do with titles that are too long, and/or specific characters in the title.
I probably take a bit longer than most people - I'd say a few minutes, possibly five, for that last thread that failed.
Is there a specific timeout, or is it variable ?
I just tried a quick test by taking a known time (just over 10 minutes) to create a new thread. I hit 'Create Thread' for that a few minutes ago and it failed. So I think you're probably correct.
Can you add a warning about the timeout to that page ? It's not the timeout itself that's the problem, but the fact that I've taken a long time to get the post correct, and when it fails to create the thread I lose everything that I so carefully typed ! Perhaps I should adopt a more slapdash approach ? ;o)
Here's the text of the thread that just failed to create (probably spurious information now):
This has happened a sufficient number of times on different machines, using different browsers, to be more than just bad luck.
I spend a long time writing a post to start a new thread.
I click the green 'Create Thread' button.
But instead of the reassuring green bar saying something about success, I get a nasty red bar like this...
That's not the bad news though. This is - I use the back button on my browser to try again...
...but everything I typed has been lost.
So I have to start again from scratch.
Please fix this.
N.B. I'm not 100% certain, but I think it is more likely to happen if there's an image in the post.
P.S. I didn't get the error writing this post - the screenshot's from the creation of another thread within the past hour or so on this same machine. So you should be able to find the log.
