Sat, Nov 23, 11:47 AM CST
Renderosity Forums / Virtual World Dynamics
Welcome to the Virtual World Dynamics Forum
Virtual World Dynamics F.A.Q (Last Updated: 2024 Nov 05 5:09 pm)
Subject: Nailing Cloth with Free Edges
creationz8 ( ) posted Thu, 02 January 2020 at 10:43 AM · edited Sat, 23 November 2024 at 9:49 AM
Hello. I bought the vwd cloth software but how do I deselect the 'free edges' to 'nail' the cloth to the collision object? I dragged to deselect but it only selects more vertices. The tutorial shows it being done but it does not mention what keys to press. Do I press ctrl, shift or alt and drag to deselect? Thanks.
VirtualWorldDynamics ( ) posted Thu, 02 January 2020 at 12:40 PM
Hello creationz8,
as I said in the sitemail, the vertices selection will be one of the first tutorial I want to do. This selection has to be able to be used in many situations.
When you select some vertices using the mouse, you can use the rectangular selection and the lasso selection. In both cases, a mouse displacement without keys (Control or Alt) will deselect all vertices and create a new selection. The same action with the Control key will add the new selected vertices to the current selection. The same action with Alt key will remove the new vertices selection from the current selection.
I will try to show all the selection vertices methods in the tutorial. I hope this small message will help you.
A happy new yera to all!
  Gérald
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
VWD3D ( ) posted Thu, 02 January 2020 at 1:12 PM · edited Thu, 02 January 2020 at 1:17 PM
Until the video comes out, after any initial selection is established (red vertices), further selection:
  • w Alt pressed, removes the new selection from the existing selection
  • w Ctrl pressed, adds the new selection to the existing selection
  • w no keys pressed, replaces the existing selection
More details in the docs, section 5.7, pg 86, and the Utilities tab's 'Mouse and Shortcuts' pop-up, also described in section 5.10, pg 112.
Hope this helps,
VWD3D (dan)
Resources: https://www.virtualworlddynamics.net - https://www.patreon.com/VWD
Rendo PM: VWD3D or VirtualWorldDynamics or support@virtualworlddynamics.net
Current VWD Version:   Release: V2.2.924.6464 - 2019/12/12, 9:46am
Qualifier: Yes, I'm helping Gérald with VWD, Nooo, I'm not yet an expert on its use!
