Sat, Nov 30, 5:08 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Concerning: Cycles Support in Poser Pro
Habatchii ( ) posted Sat, 11 April 2020 at 8:40 AM · edited Wed, 27 November 2024 at 1:40 AM
Quick question.
Cycles is the premiere render engine for Blender, from which stand alone versions may be used with other programs.
The Question: How do you configure Cycles in Poser Pro?
infinity10 ( ) posted Sat, 11 April 2020 at 8:47 AM · edited Sat, 11 April 2020 at 8:48 AM
Go to Materials Room. Right click within the Materials window. Select New Node. Select Root. Select Cycles Surface. The additional Cycles nodes are at the bottom of that pop up. Note: Blender Cycles nodes connect left to right; Poser Cycles nodes connect right to left.
Eternal Hobbyist
RedPhantom ( ) posted Sat, 11 April 2020 at 10:56 AM
Site Admin
Also, use your render settings to choose superfly as your render engine.
hborre ( ) posted Sat, 11 April 2020 at 10:57 AM
Also, not all Cycles features are included in the Poser 11, so translating nodes from Blender to Poser may not yield the same results. BTW, if you are actually using Poser 11, refrain from referring it to Poser Pro, Poser Pro is an actual, earlier version and may confuse other individuals when you are seeking help.
EClark1894 ( ) posted Fri, 17 April 2020 at 12:01 PM
Also note, Cycles nodes applied in Blender will NOT be imported into Poser. You WILL have to apply the nodes again.
hborre ( ) posted Fri, 17 April 2020 at 12:19 PM
A tedious process even if you know what you're doing.
