Sat, Nov 23, 1:46 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Is there a universal "stop this script here" command?
HartyBart ( ) posted Sun, 19 July 2020 at 7:38 PM · edited Sat, 23 November 2024 at 1:39 PM
In PoserPython, is there any universal 'stop this script here, progress no further' command?
For instance:
   actor = scene.CurrentActor()
   # If no light is currently selected in the scene, then display this message and stop the script.
   if not actor.IsLight():
      poser.DialogSimple.MessageBox("To run this script, please first select a light.")
      >>> STOP HERE! <<
   else:
      if actor.IsLight():
   # OK, we have a light selected, so continue running the script.
          lights = scene.Lights()
          for light in lights:
What needs to go on the line >>> STOP HERE! << to cause the script to exit gracefully? I see "Return" used in other scripts, but that fails to prevent the script from continuing to run.
structure ( ) posted Sun, 19 July 2020 at 8:26 PM · edited Sun, 19 July 2020 at 9:12 PM
Forum Coordinator
there is no "stop" that I am aware of but there are ways to make it do what you are asking
for instance
import poser
scene = poser.Scene()
def test_for_light( ):
    return True if scene.CurrentActor().IsLight() else False
if test_for_light():
    put the body of your script here
else:
or
import poser
scene = poser.Scene():
if scene.CurrentActor().IsLight():
    do something
else:
    send message
but you do not need to test if the current actor is a light if you are going to cycle through the lights anyway
you could do something like
import poser
for light in scene.Lights():
    light.SetLightOn( not light.LightOn() )
doing it this way, python would only affect lights, not other types of actors.
Locked Out
HartyBart ( ) posted Sun, 19 July 2020 at 9:41 PM
Thanks you so much, Structure, that's solved it. After a bit of rebuilding I now have a working script to turn off all lights except the currently selected one, do some useful things, then turn them all back on again.
I found, though, that at first I had 'invalid syntax' error on your 'Else:' — this was fixed by indenting all the way down the script. Below is a visual example of what I mean:
    <- indent
    <- indent
    <- indent
    <- indent
    <- indent
    <- indent
    <- indent
    <- indent
    <- indent
else:
In other words, the script has to have "a clear run" down the indents to get at the "else:" command. If not then it throws an 'invalid syntax' error. This should be useful to know for other beginners reading this in years to come.
structure ( ) posted Sun, 19 July 2020 at 10:22 PM
Forum Coordinator
Glad you got it working
Locked Out
adp001 ( ) posted Mon, 20 July 2020 at 2:54 AM
There is a Python function to abort a script: sys.exit()
But in Poser-Python this stops not only the script. It stops Poser :)
Nonetheless, there is a another, "pythonic" way to interrupt a running script (even if it's nicer done with program logic).
class StopScript(Exception):
    pass
def abc(parm):
    if parm > 10:
        raise StopScript()
    else:
        print parm
try:
    abc(20)
except StopScript:
    print "Script aborted"
HartyBart ( ) posted Mon, 20 July 2020 at 5:54 AM
sys.exit()
Yes, I tried that. I'd never seen Poser exit so fast! Quicker than a Ctrl + Del and a forced stop, in Windows.
Thanks for the addition option, adp001.
