Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
there is no "stop" that I am aware of but there are ways to make it do what you are asking
for instance
import poser
scene = poser.Scene()
def test_for_light( ):
return True if scene.CurrentActor().IsLight() else False
if test_for_light():
put the body of your script here
else:
poser.DialogSimple.MessageBox("To run this script, please first select a light.")
or
import poser
scene = poser.Scene():
if scene.CurrentActor().IsLight():
do something
else:
send message
but you do not need to test if the current actor is a light if you are going to cycle through the lights anyway
you could do something like
import poser
for light in scene.Lights():
light.SetLightOn( not light.LightOn() )
doing it this way, python would only affect lights, not other types of actors.
Locked Out
Thanks you so much, Structure, that's solved it. After a bit of rebuilding I now have a working script to turn off all lights except the currently selected one, do some useful things, then turn them all back on again.
I found, though, that at first I had 'invalid syntax' error on your 'Else:' — this was fixed by indenting all the way down the script. Below is a visual example of what I mean:
<- indent
<- indent
<- indent
<- indent
<- indent
<- indent
<- indent
<- indent
<- indent
else:
In other words, the script has to have "a clear run" down the indents to get at the "else:" command. If not then it throws an 'invalid syntax' error. This should be useful to know for other beginners reading this in years to come.
There is a Python function to abort a script: sys.exit()
But in Poser-Python this stops not only the script. It stops Poser :)
Nonetheless, there is a another, "pythonic" way to interrupt a running script (even if it's nicer done with program logic).
class StopScript(Exception):
pass
def abc(parm):
if parm > 10:
raise StopScript()
else:
print parm
try:
abc(20)
except StopScript:
print "Script aborted"
sys.exit()
Yes, I tried that. I'd never seen Poser exit so fast! Quicker than a Ctrl + Del and a forced stop, in Windows.
Thanks for the addition option, adp001.
In PoserPython, is there any universal 'stop this script here, progress no further' command?
For instance:
actor = scene.CurrentActor()
# If no light is currently selected in the scene, then display this message and stop the script.
if not actor.IsLight():
>>> STOP HERE! <<
else:
if actor.IsLight():
# OK, we have a light selected, so continue running the script.
lights = scene.Lights()
for light in lights:
What needs to go on the line >>> STOP HERE! << to cause the script to exit gracefully? I see "Return" used in other scripts, but that fails to prevent the script from continuing to run.
