Usually it means that each part of the render is rendered individually. For instance dof, diffuse etc you'll later compose these in a photo editing software, ie photo shop. You can blend the different canvasses using layer blends to set the mood of the picture or bring out a lot more detail. This is often called a beauty render.
https://www.youtube.com/watch?reload=9&v=wrsvFKNgxgU&feature=emb_logo
You probably wont have everything (dont know I dont use render passes or superfly in Poser so not sure what all it outputs ) but basically this is what you do with them.
HP Zbook 17 G6, intel Xeon 64 GB of ram 1 TB SSD, Quadro RTX 5000
BUT forgot to add, if your happy with the way your render look's and you feel there is no need to improve it even more then no I guess that's up to you, BUT no matter how good you think it looks, there's always room for improvement. renders / photos / anything.
Uhmmm, with Superfly and Cycles Root nodes or Physically-Based Root nodes, is there any reason to use RenderPasses ?
Eternal Hobbyist
