Poser 12 F.A.Q (Last Updated: 2024 Nov 29 11:16 am)
from what i've seen so far there's no diff. but then again i'm colourblind. ;)
"Dream like you'll live forever. Live like you'll die tomorrow."
@RedPhantom The issue in the past with CPU renders looking different than GPU render was down to the clamp settings. In CPU it turned this off and (no clamping) so CPU would calculate for ALL the lighting while it turns clamping on for GPU and you can experiment with how much clamping there is. The issue was that it was never really explained to the users this would have a profound impact on SOME renders. It matters how many lights you have and how small and intense they are. It took me more than a year to figure out what exactly was going on with the renders just because it wasn't all renders. Very puzzling.
hborre posted at 9:38AM Wed, 04 November 2020 - #4403213
It looks more like no one either never notices or didn't bother to pursue further testing. I wonder if anyone opened a ticket on it.
It's not a bug, It's just the way Superfly is. It's just that there was never any official explanation as to why renders would look different. Turning clamping off makes fireflies in renders with super high dynamic range lighting. The HDR images that are dark with one or more super bright points of light in them are the ones that show this the best. The fireflies are not render errors, they are HIGHLIGHTS that take a huge amount of time to calculate. If you let the image render for 100 samples or more you will see the patterns emerge and turn into bright highlights from the sun or small, bright lamps in the hdri. Using the background to light a scene works way better but the background image is all twisted around.
Ah, that explains a bit of what I've been seeing in conjunction with some information I read in the manual. Believe me, I read those paragraphs multiple times just to make sure I understood the concept. Now, you mentioned super high dynamic range lighting and its effect on increased fireflies with unclamped rendering, am I correct to assume that if I use a lower range HDRI under the same conditions I would eliminate most, if not all, fireflies sacrificing some highlighting? This is intriguing and deserves a closer look. Thanks.
@hborre Yes, the lower the dynamic range the cleaner the render. The cleanest will be if you use a jpg instead of an HDRI. This is if you are using a dome for lighting. If you use the background as your HDRI then it renders cleaner AND you get the highlights from lamps and the sun in the image. I still haven't figured how to sort out the way the background image is all flipped around when using that. using the background for lighting is also SUPER fast. Have a look at the lighting results. That huge highlight on the figure is from the background. There are no lights used in this render.
Thanks all for indulging me. This is interesting
The twisted backgroundimage can be fixed with a mapping node. I posted the setup in my posting about the shadow catcher.
Rotation value in the mapping node: 4.900000, 3.150000, 0.000000
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.ย
Works:
HDRI-Image on the background shader.
-"Amazing
Grace" Hopper
bantha posted at 11:12PM Wed, 04 November 2020 - #4403299
Thank you so much ?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
@ghostship2: I have been playing with your node arrangement for background projection of HDRI maps and I would like to make a recommendation. Use the Normal connection on the TextureCoordinate instead of Generated, and on the Mapping node change the Vector Type to Texture instead of Point. I believe this will invert the projection. Use the upper Location, Rotation, Scale values to control the translation of the background.
@Rhia if the node is unconnected then don't worry about that. I have some voodoo about nodes for the background lighting setup because lighting a scene this way in P11 was serious Poser crash time. Looks like it is pretty stable now!!!!! This is what we are talking about:
The grey background is with GPU rendering. With CPU, what I am getting is the 'floor of the image, if you will.
I'm sure it's a simple answer, so sorry for all the questions. This program version forces me to stumble around like a complete noob for Poser after such a long time using it. Thanks for answering me!
The rotation first number should be set to approximately 90-degrees to appear normal. Click on the first rotation value at the top, you will notice 3 numbers separated by commas. In order, the numbers correspond to X, Y, Z-degrees global axis. Those numbers should look like this: 90.00, 0.00,0.00. Adjust as needed to match the HDRI.
Lol.... I don't get anything working with your settings... I have to enter -90ยฐ for X, but in radians:![Sasha-Jinky7.jpg]
I've tried Point -> generated and texture -> normal: no success. Anyway, it looks like I've found something working, yay ?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Looks like the background node is loosing its rotation and scale parameters upon reloading a Poser project file...
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Y-Phil posted at 10:15AM Fri, 06 November 2020 - #4403582
Same issue here. Also after changing the rotation values back to something usable Poser still not registering a change to the file so "save" is still greyed out. Also last night I edited a file and then clicked the "X" in the upper right corner to close the program and Poser just quit without any warning about saving my work.
ghostship2 posted at 9:58PM Fri, 06 November 2020 - #4403620
Saving the background shader as a preset doesnt work either. The rotation setting reset to 0,0,0
You've experimented that same effects as me. I suppose that the devs consider the atmosphere, the background and probably the universe objects as more or less read-only: editable as long as nothing important is changed, except when a scene is imported for example....
From what I've understood, these parameters are effectively stored in the PZ3 file (near the end) but it looks like they are not interpreted
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Y-Phil posted at 2:24PM Fri, 06 November 2020 - #4403634
It's a problem with the mapping node itself. I have a previous version of this background shader that is saved to presets that works fine in P11.
Good news: the Background node parameters seem to be restored upon loading a scene, with Poser 12.0.276
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
OK. Now that it's working can someone smarter than I explain the 3 coordinates? what value rotates the image by 90 degrees or 180 degrees? Is there a way to have the background show up in preview so I don't have to guess where the image is rotated to?
ghostship2 posted at 10:20AM Sat, 07 November 2020 - #4403675
From what I remember of trigonometry: 90ยฐ = 1.57 (rad) = 100 (grad) = a quarter of a circle
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
I know a lot of focus is on the GPU rendering because it's so much faster. Who wouldn't want a render done in 5 minutes rather than 5 hours? But has anyone tried the problematic shaders in a CPU rendering. If I recall, the GPU and CPU rendering always was different.
