Sat, Nov 23, 1:17 PM CST
Subject: Poser 11 injection problem
tbenner ( ) posted Wed, 08 September 2021 at 10:38 AM · edited Sat, 23 November 2024 at 1:16 PM
I bought Poser Pro 11 and have been reading about injecting morphs for La Femme, but how do you do this, and where are the injection morphs stored? The only thing I've found is in the la femme/morphs/oot/femme faces folder there are some INJ files, like OOT Hannah INJ. This is all I can find.
Everything I've read so far seems to assume you know where these files are for la femme. Can someone please help?
Thanks
[Tim]
randym77 ( ) posted Wed, 08 September 2021 at 11:47 AM · edited Wed, 08 September 2021 at 11:48 AM
INJ files are usually in the Pose section of the library. According to the readme, the INJ files are in
Runtime->libraries->pose->RPublishing->LaFemme
But they've moved around with different versions of La Femme, so if you don't see them, look around. They should be somewhere in the Pose section of the library.
Miss B ( ) posted Wed, 08 September 2021 at 11:53 AM
Did you purchase La Femme Pro as well, or are you using the standard La Femme that comes included with Poser Pro 11?
I ask because I have the Pro version of La Femme, and also have Deecy's La Femme Body Kit MR, which has a number of body injections, which I think is what you're looking for. You can find it here --> https://www.renderosity.com/rr/mod/bcs/la-femme-body-kit-mr/135148/
If you don't have the Pro version of La Femme, then I'm not sure if you can use the Body Kit. Someone else would have to answer that question.
Sorry I can't be of more help.
_______________
Butterfly Dezignz
randym77 ( ) posted Wed, 08 September 2021 at 12:05 PM
La Femme did come with some injectable morphs, but it might be the pro version only. I'd check, but I'm not at my Poser computer right now. I bought La Femme before she was included in Poser, so I don't remember what was included in the base figure. I don't think I've ever used it.
Miss B ( ) posted Wed, 08 September 2021 at 1:45 PM
I haven't used the base La Femme figure either. I do, on occasion, use the base L'Homme figure though, as I didn't buy his Pro version, and I don't see any morph INJ files for him.
_______________
Butterfly Dezignz
hborre ( ) posted Wed, 08 September 2021 at 2:06 PM
The pro pack comes with Femme Fatale morphs by Blackhearted and the pro body and face morphs. As Randym77 posted, all the injection morphs are located under the Poser category and nowhere else. Poser 11 only comes with the stripped-down La Femme package, everything else you'll need to purchase or download for free from the Freestuff section. This is hardly an injection problem in P11.
EVargas ( ) posted Wed, 08 September 2021 at 3:59 PM
@tbenner I had the same doubt after purchasing Poser 12, the reality is that, as already explained by the fellows here the base figure is just basic. It has good controls for eyes/phonemes/expressions but lack advanced morphs for the more enthusiastic user. In case it helps you decide I end up buying the following, which is usually suggested by others as a good list and I found it a nice combo:
La Femme Pro - V.2 <- look at this one first
Femme Fatale HD Morphs for La Femme
Femme Fatale Signature Set for La Femme
EVargas.Art
primorge ( ) posted Wed, 08 September 2021 at 4:41 PM
"The pro pack comes with Femme Fatale morphs by Blackhearted"
Actually, it doesn't.
hborre ( ) posted Wed, 08 September 2021 at 5:58 PM
Yeah, I realized that when I looked at my orders earlier. My bad.
