Poser 12 F.A.Q (Last Updated: 2024 Nov 29 11:16 am)
What I did was go to Edit > General Preferences > Interface > UI Scale (bottom left) and changed it.
I believe the default is 1.0, and I reset it to 1.35. I tried 1.5, but it doesn't work for me, but I'm on a laptop with a 15" monitor, so if you're on a desktop with a large separate monitor, you should be able to raise it even higher. It will need a restart of Poser in order to see the change.
Also, and this may not happen on your large monitor, but I found the 1.5 UI Scale moved parts of the UI that aren't necessarily text, but are adjacent to it, depending on how you have all the "windows" arranged, which caused visual issues, which may be what's happening in your first screenshot.
_______________
Any time an application is not doing a good job at scaling, you can try asking Windows to handle it instead:
* Right-click the shortcut for the program
* Click "Properties"
* Pick the Compatibility tab
* Click the "Change high DPI settings" button at the bottom
* In the next window, check the box for "Override high DPI scaling behavior" under High DPI Scaling Override. There are three choices, Application, System, and System (Enhanced). All of these do different things, it might be worth trying all of them.
ChromeStar posted at 12:50 AM Sat, 26 February 2022 - #4435168
Worked with a few problems left over. I used the System option. Will have to play around a bit with options since the text is a bit unclear now but on the way to a good fix and previous renders are too big to show in the preview window now. Thanks for the tip.Any time an application is not doing a good job at scaling, you can try asking Windows to handle it instead:
Poser devs can correct he issue out by including auto scaling for DPI changes in the next update.
Well rats. I thought we were headed to a solution but the lack of support for the secondary monitor is a big oversight. The render window resolution is limited to whatever my primary monitor settings are. Text is fuzzy since it is upscaled from 1080 to 4k.
Still looking for a solution but one may have to be provided in an update. Not good to release a new version of any program without secondary monitor support. It's a big screwup and so far looks like I wasted the money I spent on the upgrade. All I got was headaches and an updated render engine which I can only use on my smaller monitor.
If this is how an update is released Poser is one the way to becoming obsolete. Sad since I have been a customer since the first release.
You might want to contact support https://support.posersoftware.com/. They may have more ideas and if nothing else it's a better way to make them aware of the problem. Many people use Poser with 2 monitors and this is the first I've seen this problem mentioned here. It may be something that only happens with certain setups so they may not have seen it.
I have to say that I'm using three Eizo screens, but they aren't 4k, I never use such a high definition, that probably explain why I'm not having such problems.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
My current workaround: undocked all windows and dragged them to my 4k monitor, left the main window on my 1080 monitor to select from and change options. I still have too tiny text everywhere except the library menu but I can deal with it.
The problem must be baked into the upgrade from 11 since that version works fine. I will contact support as suggested and post the fix, if there is one.
Rhia474 posted at 10:00 PM Sat, 26 February 2022 - #4435213
Something changed re. P12 or else I would have a similar problem with P11 Pro, which has no issues on my 4k monitor. Curious to see what the devs have to say about it.I would think the issue is not the 2 monitors (I use them too without problem) but the 4K resolution. The support ticket should alert the team and they may be able to have a fix in the next release.
My guess: it's related to a new environment behind Poser12's interface, the fact that it's based on Python3.x, etc...Rhia474 posted at 10:00 PM Sat, 26 February 2022 - #4435213
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
JAFO posted at 2:56 PM Sun, 27 February 2022 - #4435248
I'm running two monitors, 4K oled TV main and a 1080p secondary . I'm not having any issues.
Edit: re. A deeper look reveals the resolution on the 4k is set to 1440.
That changed my thoughts on dragging from lower to higher res. Must be a scaling problem but no idea if it happens dragging from lower res to higher or both ways.
I think Y-Phil may have hit the nail on the head: "My guess: it's related to a new environment behind Poser12's interface, the fact that it's based on Python3.x, etc...Y-Phil."
Changing the interface scale does not work. Ideas on how to fix this?
