Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
My best suggestion is to go into General Preferences and on the Document tab, set launch behavior to 'Launch to factory scene' and proceed to the Interface tab and set launch behavior' also to 'Launch to factory state'. Close the panel and reboot Poser. Afterward, reset the General Preferences back to your previously selected state. Unfortunately, If you customized the UI, you will need to manually restore the panels where you want them. Use the UI Dots in each room to preserve your setup, and prevent any accidental panel movements by unchecking 'Drag-Docking Enabled'. I spread my workspace over 2 monitors so I use the Docked/Floating features exclusively to rearrange my panels.
And once everything is correctly setup: alt-click to clear a position, click an empty one to store, click a used one to restore the UI.
Very handy as from time to time, Poser moves weirdly a window toolbox
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I recently tried to use the Fitting Room, but the display panel is a long, narrow strip at the top of the page. There is NOTHING else. I tried to load the other controls, but they're all over the place and never looks like the picture in the "Room Help" or in the forums.
Every problem in the forums seem to be with working Fitting Rooms, but how can I get mine to just get started?
