Wed, Dec 11, 5:55 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Nov 29 11:16 am)
Subject: Queue Manager Problem Sloved?
JAFO ( ) posted Tue, 16 August 2022 at 1:57 PM · edited Wed, 11 December 2024 at 5:42 PM
Solved for me anyway....
I haven't been able to use the Queue manager to render animations for quite some time, its really put a kink in my workflow. I keep trying, a few scenes worked for some reason while others refused to start, giving a .bom error. So I've gone through a long drawn out process of elimination comparing what works with what doesn't. I've narrowed it down to hair shaders, the Poser12 shaders(Natural Blonde in my case) throw the errors while  simple Hair Mats(Simple photo texture) work. Works for me anyway... Can someone please confirm or debunk this...Hopefully the next service release will address this. The Queue manager is a very important asset to have working.
Y'all have a great day.
hborre ( ) posted Tue, 16 August 2022 at 2:29 PM
I am assuming that you are not altering any Material Room shaders to work in P12.  And is this a Firefly or Superfly rendering?  It is hard to tell whether certain nodes may be a problem for Queue Manager and if you are using proprietary products then you can't post their shader node arrangements.
Have you reported this problem to the support team?  It is the only way to prioritize the problem in time for the next release.
JAFO ( ) posted Tue, 16 August 2022 at 4:30 PM
Superfly, no alterations to mat's  just double click to apply from P12 library.  I thought I had mentioned it in feature requests, but I guess I hadn't.  I know there was a thread here about the problem a couple months back.
I'll copy and paste this to feature request forum. Unless there's a better place to do so.
RedPhantom ( ) posted Tue, 16 August 2022 at 6:54 PM
Site Admin Online Now!
certain nodes cause that error in the queue manager . I found a couple of texture nodes cause it too. you'd probably be better off reporting it to support rather than posting here since this is a bug.
hborre ( ) posted Mon, 17 April 2023 at 10:00 AM
P12 is not being developed any further.  If this persists in P13 then it should be reported.
