Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
I'm running Poser11.2.319, on Windows 10, running AMD Ryzen 5 3600 with 32GB RAM and an old AMD Radeon R9-270X.
I''ve suddenly (as in just since yesterday) started getting Wacro errors poppinh up in a mainWacros window on inital start of Poser, and recurrng whenever I load a new figure or prop.
The text is:
"An errror occurred importing addon KinectCapture : ERROR: DLL load failed: The specified module could not be found. An errror occurred importing addon PythonShell : ERROR: DLL load failed: The specified module could not be found. An errror occurred importing addon KinectCapture : ERROR: DLL load failed: The specified module could not be found. An errror occurred importing addon PythonShell : ERROR: DLL load failed: The specified module could not be found."
I found this post and, following that advice, I moved the KinectCapture folder from Poser11 > Runtime > Python > addons to a separate folder outside of the main Poser11 folder (rather than deleting outright). Once I did this the KinectCapture errors were no longer appearing, so I did the same with the PythonShell folder, but now I'm getting a mainWacros popup reporting "AttributeError: loads".
What else should I try to correct this (and why might it have suddenly started after years of mostly trouble-free operation)?
