(Last Updated: 2024 Dec 15 8:29 am)
This is a quick setup using an architectural prop created for Firefly. I added the CyclesSurface and PrincipledBsdf nodes for Superfly rendering. Notice, the latest version of Poser 13 now includes a Displacement node. Plug the Displacement map into the Height channel and adjust the scale.
The images below show Superfly renders without and with displacement.
Lol... HBorre's example made me thin to... Snarly's Snow Machine.
As it's still an old Python 2.7 script (yet...), I've launch that good old Poser 11 (remember? it's a portable program...), dropped some snow on a rock.
Then, I had to find the three essential nodes: SSMTheSnow, SSMBump and SSMDisplacement. The were only moved, no parameters changed, as it's just an experiment.
With an HDRi, it gives this:
Note the new Displacement node's scale: forced to 3 to have some snow on the almost vertical parts.
What do you think?
If there's some interest, I could port the script to Python 3.7
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Here you are: a Python 3.7 version of the snow machine. Its version is V3.0.0, and the name of the script differs from the original, to avoid any problem.
The Firefly part remains the same, the script has been adapted to the new environment, plus a few details, For example, it remains floating above Poser.
The advanced tab has one new parameter: the scale for the displacement node
You may download the Python file here:
https://kdrive.digital-paradize.com/app/share/116364/2a6289f5-2a0e-4d28-8531-a9eb36bf6c5d
I am of course opened to any suggestion to enhance it, as it relies on my mid-level knowledge of Poser's materials
This year, the snow has a weird look, lol...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
philadam posted at 10:25 PM Thu, 12 December 2024 - #4492122
It's not a part that I touched, but from what I can read, the script by default looks for a PoserSurfaceNode.
When
When trying to use Snow machine 3 with all materials selected I get the above Error.
Any thoughts?
Even an empty material, based on PoserSurface, works.
This:
Gives this:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Sometimes I got this message too, if I try again it will work fine. I have no clue why, but restarting the script was always my solution :)
When
Any thoughts?
Y-Phil posted at 3:50 PM Tue, 10 December 2024 - #4492050
I'm a lowlands California boy, hence not much experience with snow. WOULD the almost vertical parts have any snow on them?Lol... HBorre's example made me thin to... Snarly's Snow Machine.
Then, I had to find the three essential nodes: SSMTheSnow, SSMBump and SSMDisplacement. The were only moved, no parameters changed, as it's just an experiment.With an HDRi, it gives this:
What do you think?
Depending on the type snow, even fully vertical surfaces might have it on them. If it's wet enough and windy enough, you may find it covering road signs and sides of trees, cars, houses, etc.
I'm a lowlands California boy, hence not much experience with snow. WOULD the almost vertical parts have any snow on them?If you mean in real life: yes it would. It is because of the wind... I think. I can even see it in the thin pillars of the street signs in winter. (forgive me please if I misunderstood your question)
Ooh, that's so neat! I'll have to try this.
