Sat, Nov 23, 2:41 AM CST
Subject: Making a posette completely white
creativechaos ( ) posted Wed, 12 December 2001 at 9:28 PM · edited Fri, 22 November 2024 at 10:54 PM
Is there a way to completely white out a posette's (or any poser models for that matter) material colors? I'm getting a little tired of having to change 20 some colors per model when I add a texture to it LOL Is there something around here maybe or a way to have some file in poser itself that could change the colors?
My Store              My Gallery
Remember...getting lost is the senic route to the eventual destination. (And a lot prettier than the straight road)
fauve ( ) posted Wed, 12 December 2001 at 9:33 PM
Do you have Poser Pro Pack? If so, Philc has made a very useful Python script that sets all object materials for a figure to white. Check the Freestuff for it under his username. -nemo
Kiera ( ) posted Wed, 12 December 2001 at 9:37 PM
Hmm... wouldn't it technically be possible to make a MAT file that is set completely to white with no texture loaded? AprilYSH's (hope I remembered that right) remapped Posette is set that way.
creativechaos ( ) posted Wed, 12 December 2001 at 9:43 PM
No, I don't have Pro Pack. I use Poser 4 both in school and a copy that we got deals on from school. It's still the MetaCreations version of Poser.
My Store              My Gallery
fauve ( ) posted Wed, 12 December 2001 at 9:47 PM
If you search the Freestuff area for MAT files, I think there is a white posette MAT there... I know people have done white MATS for the horse and the Poser man. If there's not one there, let me know and I'll make one and put it up. (You probably already know it, but a MAT file is a pose file that changes all the material settings of an object. I think it should work in your version of Poser.) -nemo
creativechaos ( ) posted Wed, 12 December 2001 at 9:53 PM
Yeah, I've figured that out...but I've also been running into problems with characters like Eve 4, Poser keeps telling me that she has a newer version number and it can't read it :( But I'll check and let you know. Thanx for the help so far.
My Store              My Gallery
Kiera ( ) posted Wed, 12 December 2001 at 9:57 PM
I get that too, and I am using 4.03. I think it has something to do with Pro Pack. I am one of those old geezers. Poser 4 is in the MetaCreations folder.. along with Bryce and Painter. =p
ronknights ( ) posted Wed, 12 December 2001 at 10:01 PM
Attached Link: http://www.curiouslabs.com/
The first question: Have you installed the patch to bring Poser up to version 4.03? If you haven't, follow the provided link to their site and download and install the patch. This is very critical, since it fixes a lot of bugs.. including some messages about a file being from a newer version. Now if/once that patch is installed, there is another instance in which you'll get this "newer version" message. If someone creates something in Poser Pro Pack, you get that message. Usually Poser 4.0X complains a few times, but survives. You might consider resaving the item into your library with the same name. That way you won't get the message again.
creativechaos ( ) posted Wed, 12 December 2001 at 10:25 PM
Ahh...found the white pf woman...Thank you for the help :) Someday I hope to get this totally!
My Store              My Gallery
Staale ( ) posted Thu, 13 December 2001 at 11:03 AM
Attached Link: http://home.online.no/~kjellil/
The version { number 4 } is the Poser version, if you set it to a higher number than you are running you get the irritating, "This file has a newer version number than expected, Poser will attempt to read it anyway" error. Simply open the model in a text editor and change the number. It's in the begining of the file as seen in the image above. BTW. Thats a one channel bodymorph pose. Staale.
VirtualSite ( ) posted Thu, 13 December 2001 at 2:05 PM
If all youre doing is making the entire figure white, wouldnt it be easier to simmply make the object color for the body white and click the "change applies to all body parts"? Usually works for me, unless I dont understand what youre asking for here.
azl ( ) posted Fri, 14 December 2001 at 11:02 AM
Attached Link: http://www.renderosity.com/~azl/
I have several MAT files on my site to make Posette (and other Poser figures) white.
Click on the link -- then click Freebies and then Textures.
