Fri, Nov 29, 11:08 AM CST
Subject: Re: Allerleirauh's hair in bryce
Jim Burton ( ) posted Thu, 16 December 1999 at 6:51 PM ยท edited Mon, 21 October 2024 at 11:21 PM
As requested, is is a screen shot of the Bryce Material Lab settings I used. I used Photoshop to make the texture map into a brunette-color map (texture A), the transparency map is unchanged as texture map B and the texture map was modified to be the bump map (again in Photoshop) as texture C. (You could problay use it as-is, with higher bump settings). Don't forget to turn on blend transparency. I'm going to post the picture in the gallery too, I think.
picnic ( ) posted Thu, 16 December 1999 at 8:12 PM
Thanks Jim. I didn't do the 'bump' and I think that helps a lot. Diane B
LoboUK ( ) posted Fri, 17 December 1999 at 3:56 AM
That's great Jim, I'm very grateful that you've posted that. Now, maybe, I can get the hair to look right :) Paul
rtamesis ( ) posted Fri, 17 December 1999 at 2:37 PM
Could you post your brunette Allerleirauh hair color map too? Thanks!
Jim Burton ( ) posted Fri, 17 December 1999 at 3:24 PM
I could only post if it Allerleirauh says its O.K., as it's his map with the colors modified
picnic ( ) posted Fri, 17 December 1999 at 5:34 PM
rtamesis, why don't you dl the hair and then take it into either PS or PSP and color it. BTW, Allerleirauh is a woman LOL. I believe the hair is in Funstuff. I actually colored mine right in Bryce in the material lab--you can do that too, by setting all your colors--diffision, ambience, etc.--look at Jim's image above. Diane B
