Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
How about this:
Here is a quick sample with an Anything Grooves table top of course.
Good Luck,
Eric Winemiller
Digital Carvers Guild
Freeware and commercial 3D extensions
http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
Thanks to all, i have resolved the problem with a mask and a massive post production. For Eric, your solution is very good, but i have many more holes (like my pic) and compound operation not work perfectly. For Mark, i have Amapi 5, but i have problem to import illustrator files. However, many thanks to all :) Toxe
Toxe, If you're still trying to build the bowl with holes, I actually created the entire object in Amapi with no Illustrator imports. Just step and repeat operations with a cylinder. I don't have any insight into the import problems. I would have guessed it was just not saving the files to be importated as AI v3 files. Post back if you get it figured out! Mark
Okay,I will have to admit,my jaw dropped when I saw the perforated pots and two table tops.So are they pics or what? Whew! I think I am sticking with carrara(though it crashes each time I try to render it could be fixed I guess)whew,i am going to get all the digital carvers plug in( I only wish they've got some hair stuff)
