Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
I've run into this--varying light intensities (one set at 100%, one at 80, say, one at 75 or whatever) seem to cause this effect--it's more a matter if highlighting than shadow, I think. This figure appears to be backlit, too, from the right, with a very intense light. Looks like a less intense light from above, left, and another from low front, slightly left. You might try moving lights around a bit to get rid of the backlighting, and/or evening out the intensities. Hope this helps.
To answer your question, you might try using spot lights instead of global lights to fix your problems. I find spot lights extremely helpful in situations where you want to light a very specific position of the body. Just create two more lights, double click on them to change them to spot lights and scale it down and position them to hit across the back and below the face. Hope that works. I like her hair.
HeelInFix on each foot. after this: interpStyleLocked 0 add this in: valueOpDeltaAdd Figure 1 lFoot:1 xrot deltaAddDelta 0.030000 (rFoot:1 for the right) and it will set automatically when you bend the foot (JCM) Of course you better pay attention to which is Figure 1 (cross-talk) But burning Figure 1 with a Null works. (it follows its own rotation in any case)
There is one chronic problem with Vicky (and Mike too I think.) It seems that some poses meant for the P4 characters don't work exactly right for Vicky and Mike. That is why there are poses made especially for Vicky and Mike, or people often need to tweak and fix things. I guess I do sleep. I'd been working days recently...but now.... well I may be staying up later for awhile.
