Fri, Nov 29, 3:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: Little Dragon, you wanted a spiral staircase.....
Maz ( ) posted Tue, 08 January 2002 at 6:19 PM ยท edited Mon, 25 November 2024 at 2:34 PM
Work is progressing on my cartoon + line dungeon kit and as requested I've now added a spiral staircase. Is this the sort of thing you had in mind? It does a full 180 degree turn. With a bit more effort I should be able to join several together on top of each other to make a full staircase of any height. This image shows seven different components joined together to make a scene (not counting the iron rings). There are already quite a few others prepared but I need to make minor adjustments to them all so that they interlock perfectly before I release them. I'm also working on a variety of floors and ceilings. I haven't started a vaulted ceiling yet, but it shouldn't be too far away.
Little_Dragon ( ) posted Tue, 08 January 2002 at 9:38 PM
That is excellent work. Yes, the staircase is what I had in mind. How are you planning to release these: the Marketplace or Free Stuff?
Aureeanna ( ) posted Wed, 09 January 2002 at 3:13 AM
it was a freebie when I got it....
Maz ( ) posted Wed, 09 January 2002 at 3:16 AM
It'll be Free Stuff. If I ever do a version with textures then I might charge for that.
