Sat, Nov 23, 11:22 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Morph help !!
dwmdesigner ( ) posted Mon, 28 January 2002 at 2:11 PM · edited Sat, 23 November 2024 at 10:55 AM
I am trying to make some custom morphs but I keep running into the same problem: after I create the Morph it makes the custom Dial and when I test it it just makes the face look like it was deformed at birth or is in the process of exploding! I followed these steps: 1)using the Heirarchy editor I delete everything except the head (male or Female) then I export it as a .obj . 2) then I import it to ZBRUSH and alter the Mesh, and export it as a .obj file again.I save it in my Geometries folder in Poser 4. 3)then I open Poser again and click on Object/Properties and click on the Face: Add Morph Target/ then I open the file. The only problem I can think of is maybe it needs to be resized or something..? Attached is a pic of the Morph obj and the melted/messed-up head. ANY HELP WOULD BE APPRECIATED !!! PLEASE HELP !!
Lemurtek ( ) posted Mon, 28 January 2002 at 6:04 PM
I don't really know anything about Z-Brush, but exporting from poser can be a bit tricky. First, you don't need to actually delete anything, just use the export Wavefront object, when the hierarchy list comes up, uncheck universe, then check the body part you want. In the options, make sure save as morph target is checked (this will save the object file in it's original location, which is what you need for morphs), and weld is unchecked. When modeling, make sure you move change only the points you want morphed, if you move the entire part, even slightly, you get bad results. Also be careful not to delete or add points, or do anyting that might change the order of the vertices. Regards Lemurtek
Jaager ( ) posted Thu, 31 January 2002 at 3:50 AM
Will Z-Brush allow deletion of groups? If so, import the whole geometry from Geometries and isolate what you want in Z-Brush. If you cannot, get a copy of Compose and isolate groups with it. You probably have a trans effect there, done by Poser, before you exported the group even. I know that I am the only one who hates Poser export to produce root stock for morphs, but I do. I do not clutter my Geometries folder with morph obj. Poser 'looks' in My Documents (I am insulted by that name, as well as MY computer - tacky, saccharin) I have a ton mole of morph folders there.
dwmdesigner ( ) posted Thu, 31 January 2002 at 3:58 AM
Thanks but I solved my problem already, I wasn't getting the pop-up window that allows me to select "Save as Morph Target" so I installed Poser Pro and I got it working, another thing I messed up was, I smoothed the mesh, so it made too many Vertices!Instead of smoothing I altered it as is and it worked fine. Propsculptor
