Sat, Nov 30, 9:42 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: MetaBalls
Grimpup ( ) posted Thu, 30 December 1999 at 9:36 PM ยท edited Thu, 15 August 2024 at 8:11 AM
I have created a form using MetalBalls. If I apply a custom texture it dose not render. Color shaders and the likes work fine, texture map is a no go. Help.
ClintH ( ) posted Fri, 31 December 1999 at 9:59 AM
Hi GrimPup, I havent played with the MetaBall modeler in Carrara yet. So, This morning I did a little test. Created a few metaballs posative and negative..ended up with a funky shape. Went into the Texture room and loaded a T-Map into the color channel and it DIDNT display the T-Map. It changed colors but the T-Map wasnt shown when I rendered. Looks like a problem to me or a limitation in the MetaBall Modeler. Clint
Clint Hawkins
(Zakk Wylde (2007))
hund ( ) posted Fri, 31 December 1999 at 11:31 AM
I can shade my metaball objects with carrara using texture maps. try applying the shader to the objects in assemble mode.
martialf ( ) posted Fri, 31 December 1999 at 1:03 PM
Me too i can shade a metaball objet in assemble window i just did it with a objet lookslike a weird dog and a texture drag from shader browser:see it on shading,on fast render button and on a rendering window It is on a PIII and 256 ram and Win98se
ClintH ( ) posted Fri, 31 December 1999 at 4:17 PM
hund & MartialF, Shaders appear to work fine. Are you using Texture Maps in your Color channel in the shader? Its Texture Maps that we seem to be having a problem with. Clint
Clint Hawkins
(Zakk Wylde (2007))
martialf ( ) posted Sat, 01 January 2000 at 4:50 AM
I just try it ,CLinth.You are right i make a metaball ,go to shader ,put a map on color layer,go to assemble room and metaball not render with texture I also create a shader with only texture for a vertex objet,save it on browser,try after to put on metaball objet ,no rendering.Hope a patch will correct it
ClintH ( ) posted Sat, 01 January 2000 at 9:18 AM
OK - Whew! I thought I was loosing it. Thanks for replying on this. Happy New Year to you. Talk with you soon. Clint
Clint Hawkins
(Zakk Wylde (2007))
Grimpup ( ) posted Sun, 02 January 2000 at 12:17 AM
Ok. Change the mapping mode to flatmapping and the texture will appear.
martialf ( ) posted Sun, 02 January 2000 at 5:27 AM
I try now Grimpup.Thanks.It working also with parametric or other mapping mode .You just must select one.
ClintH ( ) posted Sun, 02 January 2000 at 9:32 AM
AHHH YEEE!!! Thanks guys. Clint
Clint Hawkins
(Zakk Wylde (2007))
