Forum Moderators: Staff
Jim, I use Poser with the Propack and a dual boot setup. Win2k&Win98 using FAT32. I can render up to 4090 pixels and I only have 128meg RAM. So I'm guessing this is a system related problem. If you are using Poser4 without the ProPack. There is a patch on the curiouslabs website that is made for people who are using Win2k. If you haven't installed it. You should give it a shot. ScottA
Hmmm...It's been a while since I used Poser without the Propack. But I think the 4.03 update was the one I used to fix my Win2k troubles. So I guess you've already got the best update installed already. The "Insufficient filespace" error might be leading you in the wrong direction. Something as simple as Windows not knowing where your temp folder is located can cause that error. And you could be chasing a ghost. I'm not sure I could figure it out unless I had the system in front of me to play around with. ScottA
I'm on W2k now, but I had this problem a while ago in Win95/98. When I phone Medicreations about the problem. I was told that Poser 4 uses the environment variables TEMP or TMP for locating its temporary files. So you might want ot point these variables to a directory on the disc with the most free space. To set these variables or check them do the following... 1) Press the Start Button 2) Seleect Settings->Control Panel 3) From the control panel select the system module 4) In the system module select the Advanced tab 5) From the Advance page select Environment Variables. 6) The TEMP and TMP variables should be in the User variables section You can change or create them there. Also I have been told more than once that you can go above Poser 4090 pixel limit by rendering your pic as a one frame animation using the as a series of pictures option. I have not tryed this yet though. I hope this helps, Thorgrim
I also have a dell 530 with lots of ram and lots of disk space and was running win 2000 pro and had the same problems, if I was tricky I could render at 2400 x whatever, but not above and lots of steps to get that, same messages as you show and no amount of moving temp files or switching virtual got me above that - I finally cleared out my second disk drive and installed Win xp pro on it as a dual boot and then installed poser 4.0 and then upgraded to 4.0.3 and then added pro pack and my problems are solved - I tried renders after 4.0.3 and they worked also so pro pack is not necessary - I now let win xp control my virtual/page file and can render at 4090 x 3270 and everything is ok again - if you have a separate partition and/or seaparte drive, win xp (I had an OEM version so I don't know about an upgrade) will go do a dual boot and not have any problems - this really solved a vexing problem for me - Ted
Ted, Thanks so much for the input. I had been avoiding an upgrade to XP Pro, since Win2K was doing everything for me; I'll consider it now. Any reason I should not just upgrade the entire machine? XP Pro seems like an easy step from Win2K, I'm guessing the upgrade would go smooth on such a new machine. Jim
(I've also posted this in the general section) The Poser folks and I are struggling with a problem on my Dell Precision Workstation 530 (512MB RAM, lots of hard drive space). I'm getting the "insufficient disk space" warning when attempting to render images larger than about 1000 pixels square. I've tried the "workaround", setting the pagefile.sys to 10mb, with no luck. I'd really appreciate hearing from anyone who has run into "extra" challenges in Win2K, and solved them. I really need 3000 to 4000 pixel files for my glass carving work.. Thanks in advance! Jim
