Fri, Nov 29, 6:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: Vicky lip bump map?
bigro2k2 ( ) posted Sat, 09 February 2002 at 10:33 PM ยท edited Fri, 09 August 2024 at 7:00 PM
i don't know if there are any lip bump maps for any figures, let alone vicky, but if anyone knows of any, or knows another way to get realistic lips in poser (no post) other than bumpmapping it would be much appreciated. Thanks in advance, Big Ro
Cin- ( ) posted Sun, 10 February 2002 at 12:13 AM
I don't know if there are any freebie bump maps for Vicky's lips out there anyway... I know there are several packages that come with bump maps... you can get realistic looking lips without a bump map, if the texture is done well enough, and depending on how far away the camera is from the face... appying a good bump map in an up close image would make a world of difference for realism though... Sorry, this wasn't helpful really...
bigro2k2 ( ) posted Sun, 10 February 2002 at 12:34 AM
well it at least gave me a clue that some do exist, yeah my texture looks good on the lips from far away, but i am doing a close up image, hence the need for the bump map, but thanks anyway.
Cin- ( ) posted Sun, 10 February 2002 at 12:43 AM
You can turn your own texture into a bump map... just make it greyscale, and invert it... then adjust the brightness/contrast until there's a fair amount of contrast... them apply that image as a bump map. If you're not using the ProPack poser will turn your image into .bum format for you, but if you're using the ProPack you can just use a .jpg for the bump.
