Thu, Feb 27, 1:35 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: UV Mapper Pro - 3D preview mode - What paint progs. work with it ?
Norbert ( ) posted Mon, 11 February 2002 at 5:49 PM · edited Thu, 27 February 2025 at 1:35 AM
Since the demo doesn't let you try 3D preview, Id' like to know what programs besides Photoshop that people have found that it also works with. Corel? Photoimpact 6 or 7? Painter 5 or 6? Thanks, Norb
SAMS3D ( ) posted Mon, 11 February 2002 at 6:02 PM
It works with just about any of them. Sharen
Little_Dragon ( ) posted Mon, 11 February 2002 at 6:04 PM
The website does say any 2D paint program. I hope this includes Paint Shop Pro.
PhilC ( ) posted Mon, 11 February 2002 at 6:04 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=566762
As far as I can tell any graphics program that can send a copy to the clipboard. You may also find the earlier thread of interest. In it I have posted a screenshot of it being used with Photoshop.
Penguinisto ( ) posted Mon, 11 February 2002 at 6:25 PM
Attached Link: http://www.gimp.org
GIMP should work with it, and it's free (link up top)
SAMS3D ( ) posted Mon, 11 February 2002 at 6:34 PM
You can keep uv mapper pro up on top of your paint program (after you make it a smaller window) and then load your texture map to it and see right away what it will look like. Sharen
Norbert ( ) posted Mon, 11 February 2002 at 7:28 PM
Thanks.. Guess I'll just go ahead and get UV Mapper Pro.
geep ( ) posted Mon, 11 February 2002 at 9:01 PM
... I am more impressed with the way it was put together and it's capabilities.
You can do things with UVMP that you can't do with any other program. IMVHO
cheers,
dr geep <------------------(a VERY happy [UV] Mapper [Pro] ... not me, the program)
cheers,
dr geep ... :o]
edited 10/5/2019
STORM3 ( ) posted Tue, 12 February 2002 at 7:22 AM
Bought it. Steve it is great!
It is a superb program and I can't wait to get my new system built which will have a dual monitor graphics card. Paint program running on one screen and full screen 3D preview running on the other (and then add the right click zoom ability and this rivals much of what Deep Paint can do, but in a far more user-friendly way).
BTW has anyone tried this with dual monitors yet?
Another question, Steve shows in his tutorials how to create an action in PS to update the 3D preview by just pressing F2 or any other nominated key.
Is there a way of doing similar with PSP 7?
Thanks
STORM
geep ( ) posted Tue, 12 February 2002 at 11:10 AM
... do it.
While you are in PSP just do this ...
(with NO area selected)
[menu] "Edit" (click) ----> "Copy" (click)
This copies the entire pic to the clipboard and then UVMP gets updated from the clipboard automatically.
Only two mouse clicks. It's fantastic!
Note: for this feature to work,
while in UVMP ... do this ...
[menu] "View" (click) ---> "Auto Update" (click)
Now "Auto Udate" will have a check next to it. (.i.e., it's active)
You only have to do this once to turn it on.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
STORM3 ( ) posted Tue, 12 February 2002 at 1:04 PM
Thanks geep Works fine. Here is an obvious but easily overlooked trick for working with layers and the 3D preview. If you update the Model only the current layer wil be selected so you have to merge to preview all layers on the Model. Do this but then back in PSP just undo the merges and back to workflow. STORM
geep ( ) posted Tue, 12 February 2002 at 1:56 PM
You are absolutely correct STORM. Thanks for pointing that out. Thank GOODNESS for that "undo" feature! It has saved my butt many times. dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
x2000 ( ) posted Tue, 12 February 2002 at 2:58 PM
OK, this is probably a dumb question, but I don't know anything about PSP, and I've only just learned about UVMP, so... the method you just described for PSP, is that a way of getting around the "actions" macro-recording thing, or do you still need that, too? Does PSP have that? See, I'm working with Photoshop 5.0 LE, which DOESN'T have that feature, so I'm wondering if I can do this 3D viewing thing or not. I downloaded the UVMP demo, but that doesn't allow this previewing business anyway, so I can't even try it myself and see, and I don't want to buy UVMP until I can use this feature. So what's the deal? Am I going to have to buy PSP (the full Photoshop is beyond my finances, I'm afraid)? Or can I manage with my sad, pathetic little Photoshopling?
Kiera ( ) posted Tue, 12 February 2002 at 3:00 PM
Any program that can copy to the clipboard should be able to do the auto-preview mode. (I don't have UVMapper Pro, just going by what others have said.) I am not sure what actions or macros have to do with UVMapper.
geep ( ) posted Tue, 12 February 2002 at 3:12 PM
When UVMapperPro (UVMP) is set to "Auto Update" mode ...
UVMP does not care which "paint" program you used to produce the "picture." (i.e., "... use any 2D paint pgm.")
When the data on the clipboard changes, UVMP senses this and updates itself. It couldn't be much simpler that that, could it?
You just use whatever command (or menu item) in the paint program you are using to copy your pic to the clipboard and the rest happens automatically.
Thanks, Steve Cox, for including this completely "user friendly" function in UVMP.
cheers,
dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 12 February 2002 at 3:14 PM
The above does NOT involve any "macro recording" whatsoever. dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
x2000 ( ) posted Tue, 12 February 2002 at 3:16 PM
Steve uses the "actions" macro-recording feature in the tutorial on his site, so I'd assumed it was a necessary feature. But if not, then PS5LE will be enough to get the job done.
x2000 ( ) posted Tue, 12 February 2002 at 3:19 PM
Oops, Geep posted twice while I was typing. Damn I'm slow! Anyway, thanks for the good news. Here I was, worrying over nothing. I guess Steve's about to make another 50 bucks...:)
geep ( ) posted Tue, 12 February 2002 at 3:20 PM
If you can "copy to clipboard" then you can use ... "Auto Update" in UVMP. It's as simple as that. cheers, dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
