UV Mapper Pro is great! I'm really happy with it. I haven't explored all its features yet, but there are two things I have tried and the program worked very well: 1. You can work on a texture in a 2D paint program (e.g. Painter, Photoshop, Paint Shop Pro, etc.) and have the UVMPro window open on top of your paint program, showing the texture on your model. You make a change in your texture, hit some keys, and presto! you can see the changed texture on your model. You can turn the model around, zoom in, zoom out. 2. Many times when you make a prop in a 3D modelling program and bring it in Poser it somehow just doesn't look right. UVMPro can help in this, too! E.g. I had a shield that I made in trueSpace, but when I brought it in Poser the surface of the shield wasn't nice and smooth but wavy. UVMPro could fix that problem and now the shield looks perfect in Poser. There are 4 tutorials on the website which tell you how to do things, one of them deals with this issue. So I can really recommend the program, I'm very happy with it. The free demo version doesn't save and the Pro version is about $50, but I think it's worth it. Hope this helps! :) Sue
Attached Link: http://www.geocities.com/lithunwrap/
try this, it has some of the same features as UVM-pro. this guy has frequent bandwidth problems but keep trying.yeah but the lith doesn't do poser? Is there a patch somewhere that includes this or no?
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
What feature do you want to try out? If it's the texturing and checking how it'll look on the model, you can do that with the demo, just not as easily. You can make your texture change, save it, then load the texture in UVMPro and see how it will be on the model. I think you can also do the fixing of the edges part with the demo. Yes, you can't save your work. It would have been better if the program allowed you a limited number of saves in order to be able to fully evaluate the features. But I can tell you that the program works great for me, and if you have any problems, I am sure that Steve will be there to help.
No, you don't see the change right as you're drawing it. The way it works in Photoshop is this: (First, you check "Auto Update" in UVM Pro) 1. You make your change 2. Select All -> Copy (or, if you have layers, Copy Merged) 3. The change shows on your model in UVM Pro. You can also set up a macro in Photoshop, so then instead of doing those two things involved in step #2, you just hit F2 or F3. (I only have Photoshop LE, and it doesn't do macros, so I have to do all the steps myself, but it's no big deal.) It would be great if you you could see the changes right as you're making them, but it's still much better than having to make the change, saving it, loading it in Poser, and rendering to see if you need to change something. It's especially important when you have to carefully line up patterns. Hope this helps! :) Sue
Is there one? And if so can I get the url please? Thanks, Marque
