Fri, Nov 29, 12:56 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Poser Prop/Modelling/Morph Question
TalmidBen ( ) posted Wed, 13 March 2002 at 10:30 PM ยท edited Fri, 29 November 2024 at 12:46 AM
I've created an object in Milkshape3d (don't laugh, I don't have a ton of money) - but I import it into Poser as an .obj file. Now, I've created a morph for it (it is a cross, that will hopefully work with the free necklace Daz gave away) - but I've created a morph for it, to make it kind of the "Millenium Cross Pendant" - and the morph works well, but the problem is when I apply the morph, the entire object grows larger, apparently applying the shape of the obj to the obj itself . . . sigh. Any help folks? Ben Burton MessianicArt.com
geep ( ) posted Wed, 13 March 2002 at 10:39 PM
Somewhere, you must have changed the "scale" of the object.
(i.e., made it larger)
When you create an MT, NEVER change:
  • the position of the object
  • the overall scale (size) of the object
You may not have done this deliberately, but may have happened when transferring between programs. All programs seem to generate their own "scale."
If you do change either the scale or position of the object, the MT will not work properly.
You can only move individual verticies when you create an MT. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TalmidBen ( ) posted Wed, 13 March 2002 at 10:53 PM
Hey friend, thanks for your willingness to help. I didn't adjust the scale, and I only move individual vertices. What I did was model a cross, export it as an obj. Then, I took the same cross I just exported, moved the ends out a bit via the vertices (to change the shape of the cross a bit, adding no new vertices (which wouldn't work anyway), or the scale of the obj.) Exported that obj. I import the object into Poser, double click on the obj, click on the new morph target button, select file of the obj I just exported, and it all works out. When I use the new morph dial I have just created, the morphs work fine, but the overall scale of the object increases. =-( Thanks much for your help!
geep ( ) posted Wed, 13 March 2002 at 11:14 PM
When you exported it, did you export "as a morph target?" If you did, try exporting it WITHOUT this box checked. Just a thought. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Little_Dragon ( ) posted Thu, 14 March 2002 at 12:15 AM
Another thing you might try when importing into Poser .... The Prop Import Options panel has an option called "Percent of standard figure size". If this option is checked, Poser will automatically resize the object on import. Any morph targets you add will still be to the original scale, resulting in size-change on use. If this is the cause, leave the option unchecked. After importing, you can use the Scale dial to resize the prop, and Poser will compensate for the Scale settings when you add morph targets.
geep ( ) posted Thu, 14 March 2002 at 12:26 AM
Is this a question of semantics? You don't really "import" an MT into Poser, do you? You actually "apply" an MT to an object. (or body part) N'est pas? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Little_Dragon ( ) posted Thu, 14 March 2002 at 12:58 AM
I wasn't debating semantics, geep. When I mentioned import options, I meant when TalmidBen imports the mesh he created in MilkShape, not when he applies the morph targets.
