Fri, Nov 29, 8:58 AM CST
Subject: Library hierarchie
sykhaloss ( ) posted Mon, 13 May 2002 at 8:53 PM ยท edited Mon, 25 November 2024 at 8:41 PM
I have too many pose sets in my pose library and i loose a lot of time scrolling to find the set i'm looking for. Is there a way to create a new library with the same level as props, pose, light,... or another way ? or am i condamned to scroll until the end of times ?!
jamball77 ( ) posted Mon, 13 May 2002 at 9:12 PM
schlabber used a utility to make his database of poses. He has a link to it on his CD and the utility is free. I'm going to get the CD out a little later. Maybe this will knock loose an idea for someone else before I can get it.
ronknights ( ) posted Mon, 13 May 2002 at 9:36 PM
Get PBooost.. It's new in the Marketplace. You'll find a few threads on PBooost here in the Poser forum.
Schlabber ( ) posted Wed, 15 May 2002 at 2:56 AM
sykhaloss: At the moment - you're condamned ... The only solution - not to have so many poses-folder in your poses-folder. Yarp P3DO-Explorer helps you organize your poses a bit. This database I've done IS a lot of work. You have to render each pose for example ... and I can't expect everyone is as mad as I'm. Sorry Ron, PBooost won't get me rid of all the problems I have - it will only move them over to other points ...
hogwarden ( ) posted Wed, 15 May 2002 at 3:17 PM
"The only solution - not to have so many poses-folder in your poses-folder."... ... but that's what PBooost does!!! Howard:)
Schlabber ( ) posted Wed, 15 May 2002 at 3:51 PM
good - OK - Howard ... but why should I need then PBooost, I can sort up my poses for myself (yeah - I still can) ?? We need more than just another Directory - sorter ... At the moment I don't know what - really. I'm more than happy with P3DO - but for sorting up my poses ?? no programm can help me doing this - I have to find my own way to work with poses ...
Schlabber ( ) posted Wed, 15 May 2002 at 3:52 PM
oh - btw ... this won't mean anything bad about PBooost ... :o).
ronknights ( ) posted Wed, 15 May 2002 at 9:32 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=661631
One thing you can do with PBooost, is use banks to separate your poses into a structure that is easy to work with. Schlabber, I happily downloaded and installed every free pose you ever offered (at one time). That made my Pose library absolutely huge. Here's an example of what you can do with PBooost: 1.) Create a bank for P4 Poses (if you don't use P4 characters much, you can have them tucked out of the way... ) 2.) Create a bank for Michael Poses and MATs. 3.) Create a bank for Vicky Poses and MATS. Now when you run Poser, you only see what is in one bank at a time. You can switch between banks to see the other stuff you need. This is easier if you're able to run Poser and PBooost at the same time because you can switch banks as you work. If PBooost won't work with your Windows XP or Windows 2000 configuration, you can still create banks. You'd just need to quit Poser to switch between the banks. Check out the provided link for an illustrated example! Ron ![Message671422.jpg](http://www.renderosity.com/photos/Message671422.jpg)
