Fri, Nov 29, 4:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: Spandex Vicki and Mike
Grey_cat ( ) posted Sun, 26 May 2002 at 8:22 PM · edited Mon, 25 November 2024 at 4:01 PM
I used the grouping tool to assign a new material called "Uniform" to the areas covered by the spandex morph. I feel this works better than the Catsuit, because it's part of the figure rather than a separate figure, and all the morphs work. They use a new object file, and a new cr2 file. If there is enough interest, I will try to make them available for free.
Grey_cat ( ) posted Sun, 26 May 2002 at 8:24 PM
Voluptuous Vicki using the "UniformF" object file.
Grey_cat ( ) posted Sun, 26 May 2002 at 8:25 PM
One of my characters using the "UniformM" object file.
queri ( ) posted Sun, 26 May 2002 at 8:35 PM
If you have Stephanie, could you do one for her too???? Emily
movida ( ) posted Sun, 26 May 2002 at 9:43 PM
really clever, I'd like it also if you can, and thank you
PabloS ( ) posted Sun, 26 May 2002 at 9:47 PM
I'm interested! However since it sounds "derivitive" you might run it by Daz first.
Grey_cat ( ) posted Sun, 26 May 2002 at 11:09 PM
Stephanie won't work, there's only a partial spandex morph (chest and hips), I need the neck and wrists to tell where to end the material change. The object files will be pcf encoded, but I'll still need DAZ's OK.
Dave ( ) posted Mon, 27 May 2002 at 1:33 AM
Mike morphs can transfer to Stephanie so you might be able to move what spandex morphs you need to her. I would also be interested in this Uniform characters.
FishNose ( ) posted Mon, 27 May 2002 at 2:17 AM
Oh yeah, definitely interesting! :] FishNose
bantha ( ) posted Mon, 27 May 2002 at 7:22 AM
I'm intrested to!
-"Amazing Grace" Hopper
Grey_cat ( ) posted Mon, 27 May 2002 at 10:05 AM
OK then, Spandex Stephi
Dave ( ) posted Mon, 27 May 2002 at 11:03 PM
Ok. Now when might this possibly be available? Definitely interested in Steph and Mike2
Larry F ( ) posted Tue, 28 May 2002 at 12:53 AM
That's beautiful. I'm definitely interested in that for Mike, Mike2, Steph, whosomever! Great stuff! Will that be in freestuff?
TigerD ( ) posted Tue, 28 May 2002 at 5:14 PM
Or, more importantly< when...?
spratman ( ) posted Wed, 29 May 2002 at 11:36 AM
Yeppers, I'm definitey interested. Not to be greedy a tutorial would be great too, doesn't sound all that hard. Since I've been using the Lores Vicky2 alot and I'm assuming the regular Vicky version wouldn't work I'd like to be able to take advantage of this for that model. thanx!
