Hi C1rcle! The way Awful Soul has set up the eyes, they are smart propped to the relevant eyes (left and right) when you load them; they are separate props. Awful Soul has included pose files to make the eyes work with the Daz millennium figures and the P4 figures, which work a charm. All you need to change is the pose file to get them positioned properly. Position in my pose file works-- just not the scale.
Yes, I can do that easily enough, and for that matter I don't really mind changing the scale each time-- the positioning was the hard part. If it were just for my use I would juat save a new character to the Lirary with the Awful Eyes in place. But I was hoping to make a batch of poses for the alien, and was hoping to include one to position the Awful Eyes-- not much good if it doesn't work right out of the box!
try saving it without the "include morph targets" if only for the hell of it but I've been confused by that myself and in all the props I've made recently I've saved them without the morph targets and they've worked and the original imported models were scaled down. So just try em that way. Also if you have a text editor, like Notepad or Wordpad in Windows (don't know what in mac if you're on a mac...) you can open any .pz2 or .cr2 files and if you familiarize yourself with them you'll soon see the sense of them and know how you can mix elements from other .pz2 into whatever one needs them. (ie, that's one way of doing the morph transfers that were talked about in the earlier post). Now, whether or not components of a .cr2 are compatable to the format of a .pz2 I don't know - can't remember cause I don't delve into .cr2s too much.
I THINK THIS WORKS Assuming that the eyes are props, and are parented to the body, this is how you could do it. Load your pose file into a text editor, search for the name of your prop. e.g. if the prop is called "box_1" search for "box_1". You should see these lines: prop box_1:2 { channels { Now insert the following text: propagatingScale scale { { static 0 k 0 3.4 } interpStyleLocked 0 } And resave the file. The line that says "k 0 3.4" defines the scale, the decimal point is in a different place than how it appears on the dial, but "k 0 3.4" =340%. Hope this helps.
Hmm. I seem to be cursed. Thanks all, but it still isn't working! I tried saving the pose without the morph targets. Again it went where it was supposed to go, but without the scaling. Lesbently, I tried editing the pose file but had the same result. I must admit I'm completely unfamilliar with text editing of these things. Here's what I typed: prop Mecha_right:1 { channels { propagatingScale scale { { static 0 k 0 3.4 } interpStyleLocked 0 } targetGeom Open_2 ('targetGeom Open_2' had been the next line after 'channels'). Did I do something wrong here? Does the tabulation matter? I tried to get it as it looks in your picture. Thanks!
Hi! Tried to post earlier, but encountered an inexplicable glitch. Weird. The eyes are props, .pp2 files. Oiginally, the poses I'd made applied to the whole figure. I've just tried making poses that apply to only the eye (select subset, unticked everything but the eye; should I have left 'universe' ticked?) and putting in the text you showed me. Still no banana. :( It would be very kind of you, if you wanted to have a look at the files. You're on a PC, aren't you? Mine is a Mac; I'll have to turn it around if so.
I have inserted the following code into Strangechilde's pose files, to allow them to scale the eye props, and sent them back to him/her. Strangechilde has tried these files with the new code and apparently, THEY WORK!?! So I am posting the code here for the benefit of those who are following this thread. It somewhat cut down from my original attempt. prop Mecha_right:1 { channels { #----New code starts---- propagatingScale scale { keys { k 0 3.4 } } #-----New code ends---- targetGeom Open_2 { keys
